Doors on a saff
Doors on a saff
Hi, are the doors of a saff cosworth the same as those from other saffs or are they special. And is there any difference between the doors with power windows and those without them?
as Rog says, the inside handle is different
I put doors off a K reg Azura onto my G reg Saph....... put all of my door trimmings back on and the very last screw I tried to put in would'nt go (release lever)
the hole the screw goes in is in a different place on newer doors (about 10mm higher I think)........ had to take all the trim back off to drill a hole in the right place
Think this was only on the front doors
also I had a problem knocking the pin's out of the hinges on the G reg........ but on the K reg they knocked out easy
Rear doors........ little slot for the child lock is in the wrong place
vertical on one & horizontal on the other..... can't remember which way round it was
chowfornow
14
05-01-2019 09:01 PM
Vacuman
22-09-2015 12:09 PM
