anyone ever fitted a oil temp sender to a sump??
i did buy one of them magnetic ones ... and seeing as it only ran a few miles after rebuild before oil leak (another post...grrrr)...was amazed how much metal was on plug when it was removed..
on the one i think i've got, there was a hole int he sump big enough to stick a threaded bit of bar into to give it the depth for the sender which was then braised into place
at least that way you can always remove the bit of metal you put in rather than have to retap the sump again if you over tighten it
If you want to do it properly then remove the sump and have it drilled and a 1/8 boss welded on to the sump. Plus if you just drill and tap it in situ you will end up with more metal in the sump.
If you are taking off the sump it is probably worth going big wing at the same time. I assume that you are concerned about oil temps and the extra volume would help, I expect the supplying company can make sure it has a boss on it.
mrmann
Aug 20, 2015 11:24 PM
lockie
Jul 31, 2015 10:03 PM
