Up and down movement on my steering wheel (saph)
OCD Victim
Could either be one of the bearings or the adjuster bushes have worn a little. Remove the lower cowling and see if you can just nip the adjuster lock-nut up a fraction with the lever released.
All options are easy to replace, you just need to have a look and see where it is moving, top, middle or bottom
mine has a habit of clunking now and again, I know there was a rack put in it at some stage but I wonder would this noise also come from the steering column
The bulkhead bushes are around Ł3-Ł4, that's all, some midiot on mine had replaced this, and just let the shaft lay in the bush, hadn't even pushed the centre piece down the shaft.
i had my bulkhead bush replaced too which fixed the up down movement , although
my drives down bumpy roads normally end with me pulled up , head in footwell pushing the plastic sleeve in the bush
cheers gaz .
cheers gaz .
Resident Wrestling Legend
the plastic bulkhead bush should be seen as a service item rather than fit and forget, don't know how manytimes i've changed them
there is a little locking plate that holds it in place, but failing that, use a cable tie to lock it into place over the top of the metal clip thing
when you put the stuff together, make sure you push all the bits onto the shaft and into the footwell before poking it out the bulkhead
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
