Best glue for bumpers?
I repaired my back bumper with permatex epoxy and still 2 years later it's perfect.
Imagine that someone hit my car from behind (during parking I guess) on the bumper (where the crack was) and apart from paint nothing else happened so this glue is really strong! And cheep also here in Greece costs 5 euro.
Everyone I spoke to about torn side supports recommended getting it properly plastic welded......however, I've had no luck round here getting a proper plastic welder to do it.
Depending on which part of the bumper it is, Loctite do one called "All Plastics" This comes with a little marker pen type thing you rub over the areas you want to fix and then use the glue on top. This seems to work ok ( for Ł3.99 ).
I'm not sure if there is something better but if there is I'd like to know too
Depending on which part of the bumper it is, Loctite do one called 'Soft Plastics' ( for plastics that have a waxy finish ). They also do "All Plastics" This comes with a little marker pen type thing you rub over the areas you want to fix and then use the glue on top. This seems to work ok ( for Ł3.99 )
I have plastic welded other abs plastic bumpers fine
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
Vacuman
22-09-2015 12:09 PM
