annoying knock from pass side front is back .
last year before i took car off road for winter , i had a new tca and a pair of spax front shockers put on by a garage because of an annoying knock comming from front pass side over bumps it sounded like ball joint , anyway job sorted i thought , no knocking , done about 1000 miles and its back
couple of things have sprung to mind which may be linked to the knock possibly are :
had new steering column bulkhead bush done last year and have had constant problems with it coming out ? (could there be a steering rack bush worn causing this and the knock )
also has full powerflex front end kit ? (please don't say its normal with poly bushes )
also the thread for the strut top on that side is longer than the other side is this normal ? car sits level and everything just something i thought may be significant , i don't think so because the sound is coming from low down and iam guessing the different thread lenghts is due to possible top mounts on wrong way on one side (done by garage again).
don't want to use the garage (various reasons one being losing faith in them),
want to fix myself now so i know it done properly and have time on my hands due to being out of a job at moment .
help please
gaz .
help please
gaz .
Cossiemodo
This reminds me of the knock I had on my drivers side, new TCA seemed to fix it, for a while.
Turned out the hole in the hub carrier that the balljoint pin goes into, had worn oval.
cheers gaz .
Well i was always told if you turn the steering wheel lock to lock, if it makes a cracking type noise, when the car is stationary, that means it's buggered. Had this with a few cars, always did this when i tried to turn lock to lock, i hope it's this chap, nothing worse than having a niggle you can't get to the bottom of!
Having the same trouble with my saph jusstnow, about to replace the cv also!
Cossiemodo
Well, a quick and easy way to get an indicator, pull the Torx bolt out, that's supposed to hold the balljoint pin in place in the hub - if the bolt is bent or has a bad wear patch on it, it's likely the hub is knackered.
is the bulkhead bush always such a pain for popping out , its more when i've been down the back lanes on a 'spirited drive ' within said speed limits . lol .
is the strut thread being longer on pass side normal cos if its the hub carrier i will need to practicly take of the strut so will put right if not .
rog - know what you mean about niggles , another one of mine is the mongoose system knocking on rear bumber and occasionally elsewhere , all part cossie ownership it seems . lol
charlie - will do
anyone used powerflex exhaust mounts ?
cheers for all replies chaps .
gaz .
Cossiemodo
Take the new bolt out, see if it's damaged again. My money says it will be. The TCA should be okay unless it's been run like that for ages. The stainless pin of the balljoint seems very resilient. It'll tend to wear but very very slowly.
the bottom arm is the same make as the other side they did 12 months earlier and had no problem with it .
just been out again and it seems to knock alot more when lower bulk head bush for column has worked its way out thats why i was wondering about any bushes on the rack which may need renewing ?
Will be getting access to a garage over week e nd so will get front up on axle stands and see if owt is loose on that side compared to other and also check the torx bolt .
cheers
gaz
cheers
gaz
problem found
right , been under the car today , its the hub carrier there is alot of movment from the point were the ball joint goes into the carrier . next question how big a job is this to change are there any special tools requried looks pretty straight forward . any pointers would be good too if an one has had problems replacing .
cheers
gaz .
cheers
gaz .
Cossiemodo
cheers
gaz .
cheers
gaz .
But seriously, glad to be of help. It took me ages to get to the bottom of it myself
cheers
gaz .
hub changed problem solved .
job done , replaced discs while i was there the drilled & grooved ones were well shot . its amazing how much better steering feels now even without the tracking being done actually enjoy driving it again .
thanks for pointer turboshed .
RIB1122
12-08-2015 08:51 PM
track.focus'd
12-08-2015 05:53 PM
