oil pump :(
oil pump :(
has anyone ever took there oil pump apart???
should it be smooth in side???
mine is realy rough and looks scored,
could this be why i have no oil pressure on idle but fine when driving.
thanks
spelling
thanks
spelling
thanks
i hope thats my prob then ill replace that and my shells cause they wernt to good and hopfly it will finaly be ok
speling
speling
The most important bit is the centre bit and the bit that revolves around it, as this si where the pressure is made, or lost, the inside of the pump body should be smooth, the end plate often gets a wear ridge in it from the rotor turning on it, .
take it your oil pump failed and thats what caused all the damage.
will a normal 2.0 pinto engine fit mine? its a 2wd shapphire.
how much difference is there between a standard oil pump and a high flow.
only asking as i rang woodford today and its alot of money for one and he said it was a high flow.
yip pinto one will go in if you put the top off your cosworth one onto the top of the pinto one for the spray jets.....and you should get a pinto one for less than £30.....
If thats the case when/what power level/stage of tune is an high pressure pump is required?
Also what do the chances be of your standard orginal ford cosworth oil pump being in good nick just say even after 100,000 miles i.e can they usually be reconditioned/used as ive been reading up horror stories of the cosworth/aftermarket pumps etc?
Thanks
Thanks
wheelwizardrefurbs
23-09-2015 09:21 PM
