L6 to L8 Upgrade
01-03-2009, 10:22 AM
L6 to L8 Upgrade
I'm thinking of upgrading my L6 ECU to an L8 version.
Apart from the ECU, what other parts are required ??
01-03-2009, 10:24 AM
pf o9 throttle position switch,and swop the two outer wires round
01-03-2009, 02:21 PM
01-03-2009, 02:24 PM
Quote:
Originally Posted by
Toad_RS
Is that right?? i'll have to sort that out as i wasn't aware
01-03-2009, 02:45 PM
When i converted mine,i just got an adaptor loom for throttle position sensor from car looms,for about Ł12,just plug and play,
cheeRS stu
01-03-2009, 02:51 PM
Thanks for above lads
Shall now be on the look out for a decent L8 ecu and above accessories then !!
01-03-2009, 03:19 PM
What is your reason for the change,as your 2wd ecu does most things ppl want on the road
cheeRS stu
01-03-2009, 03:27 PM
Dearo
ask shorty on here he has a fettish about L8s
01-03-2009, 04:07 PM
i have a spare mint pfr09 if you need...........and a 4x4 loom
01-03-2009, 04:16 PM
PassionFords Creator
STUCOS
cheeRS stu
To clarify, you still need the PF09 though.
01-03-2009, 08:41 PM
STUCOS
cheeRS stu
Was advised to go Closed Loop and that an L8 is required to do this ??
01-03-2009, 08:49 PM
Dearo
Or P8 yes.
01-03-2009, 09:01 PM
Stu @ M Developments
Or P8 yes.
So Stu,
What your saying is that it has to be either a P8 or L8 (Green Top)??
01-03-2009, 09:06 PM
Dearo
So Stu,
P8 or any L8 mate.
01-03-2009, 09:32 PM
Dero,stu's going to kill me here,but do you do enough miles to justify fitting closed loop,as you will need to do a fair few miles for it to pay for it's self,but yes it is a good system,have it on my own 2wd saff,supplied by stu
cheeRS stu
01-03-2009, 10:05 PM
STUCOS
cheeRS stu
Yeah Stu, I must admit it is a bit of an outlay for the closed loop set up eh ??
What other plus points does the L8 have over the L6 ??
02-03-2009, 12:08 PM
Dont you also need to wire in a lambda sensor for ruuning close loop on the L8/P8?
02-03-2009, 12:38 PM
This may be a daft question but when you change to a L8 how does it fit into the car as it doesnt have the mounting lugs like the L1 and L6?
Thanks
02-03-2009, 04:38 PM
Yes need lambda as well if not already got, all on msd's site.
02-03-2009, 05:13 PM
Cake lover!
SumpNut
Thanks
Good old velcro or swap all the L8 stuff into the L6 case.
tankybaby66
06-02-2016 02:24 PM
stevecfrst1
30-09-2015 05:18 AM
Sp3no
27-09-2015 07:23 PM
focus2351
09-09-2015 09:33 PM
