T3 turbo
oohmamama
![Question](https://passionford.com/forum/images/icons/icon5.gif)
my standard T3 turbo holds at 9.5- 10 psi and there is no smoke or oil consumption BUT I have noticed some radial shaft play
and no axial play. Its the original turbo on my sapph 4x4 which has now clocked 80K. its got mobil 1 5w/50 in it but will be changing over to mobil 15w/50 next oil change.
is this play a sign that a refit is due? i have been told that the clearance will disappear as soon as oil flow & pressure floats the bearings/shaft.
![](https://passionford.com/forum/images/smilies/shocked.gif)
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Puller of the Wrench
You only need a refit when you run out of air say on a Stage III (upgrade!) or when you have a James Bond style smokescreen behind you from the seal letting go. To tear it down, refit a new bearing and balance the shaft and reinstall it would be so close cost wise as opposed to just replacing it if it shreds itself to death.
I've had lots of turbos that had a bit of play. You should only be worried and testing for play if you have the axial and radial specs on hand to worry about along with a dial indicator. A little bit of play is ok. Defining what is "little" is the real question.
If it can actually touch when not running it won't be far behind when running till it's touching, so the question might be, how much do I want to chance shreds of alloy turbo going into my engine ?, turbo rebuilds are cheaper than full engine builds!!
oohmamama
Maybe I could explain better: It feels as it is very lightly rubbing somewhere as i was unable to see any rubbing marks at the intake + when i manually give it a spin it rotates freely and smoothly-no noises.
Doesn't the intercooler (standard) prevent impeller shreds from reaching the engine in the case the compressor fails? or are the passages in the intercooler large enough to allow these to get past??
oohmamama
A new to me T3 would be in the region of what??
I was considering doing the rebuild myself after purchasing a kit.
Is there a way of replacing all seals & bearings without disturbing the balance of the rotating setup? There is no one locally (Malta) I know of who can be trusted with the job.
a rebuild can be as little as £200 balanced; most UK companies will have no problem posting abroad to Malta
lots of trust worthy people in the UK to do the job for you
oohmamama
![Smile](https://passionford.com/forum/images/icons/icon7.gif)
i would always recommend getting the shaft balanced correctly on a balancing machine, even if you dont do it
Can you suggest any turbo works garage so I could email them?
thanks
http://www.turbocentreuk.co.uk/
http://www.crturbos.co.uk/
http://www.turbotechnics.com/docs/index.htm
oohmamama
LHD220turbo Thanks for your advice and links
Many thanks also goes to all the members who helped and are helping me to identify and solve the prob. More suggestions and opinions are welcome & appreciated
![god](https://passionford.com/forum/images/smilies/dieu.gif)
JK12
33
26-04-2021 12:09 PM
