Whining noise help
oohmamama
Whining noise help
Why do you guys think I am hearing a whining noise from the front end of my sapph 4x4 when applying the brakes to decelerate?? What is your diagnoses. Front and rear rotors are ventilated, through drilled and grooved + brake pads are EBC green stuff.
Thanks for your help and advice.
oohmamama
Thanks very much tabetha for your quick reply.
I was looking around for new rotors because the front measured 22.5mm. Do you suggest I change over to ventilated and grooved only. Would this eliminate the whine? I came across MTEC do you recommend this brand?
thanks
thanks
Grooved will still be noisy a bit less so than drilled, but it is because they deglaze the pad as it passes the grooves holes that generates the noise.
I just use cheapo discs and change every two years or pad set which ever comes first, I use Yellowstuff pads and very little noise, even though I have taken anti squeal shim off back of pads.
i would personally upgrade your pads to at least red stuff as greens are shit for a cossie.ok for cars upto 200bhp but after that go for reds
oohmamama
