Need new suspension: springs/dampers or coilovers?
I'm looking at replacing the aging standard suspension on my saff. Years of abuse has left the dampers a bit soggy, and some tool's probably cut the springs
What do you recommend as a decent replacement - bear in mind I have three fillings so springs made from granite aren't an option. Need somthing that's good for every day use, but still gives better-than-standard handling.
And, how (if at all) are coilovers better than standard springs/dampers? Is there any benefit to having them?
Depends what sort of ride you like, you know what coilovers are like from my car, a nice direct feel but a bit hard, that's what I like though.
If I was going for something with comfort I would go KONI adjustable, with chassis dynamic std ride height springs, these still drop around 1", despite thier name.
If you are off this week you can have a drive of mine to see how you like it.
If you don't want a hard ride, the only advantage of coilys is setting the height, or corner weighting.
