abs semsors
abs semsors
i want to buy 4 new abs sensors for my sapph cos.can i get them from america cheaper?i think scorpio sensors are the same.i see them on ebay but i reckon 380 each is a bit steep.i know when they were available from ford they cost £121 + vat.anybody know of anywhere cheaper that still stocks them?
i want new sensors ideally,i going to a lot of trouble making my car as 'as new' as possible and abs sensors are about the only thing left new that i dont have.i remember reading that they are still available in america.cozmeister,you sent me a abs trouble shooting p.m a while back.i accidently deleted it and saved another p.m you had sent me when i was having a clear out,i still havent tested my abs witha multimeter to see what the cause of the problem is(abs light on all the time)any chance you could p.m me it again?ta,lee
These are the only ones I've seen new... these the ones you were talking about?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=230222528146
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330259905557
Resident Wrestling Legend
don't buy them, they won't fit
they are 92 spec ones with the wrong ends
the ends are different
and you can't change them
it's something to do with the resistance in the ends as these are different pluged with just 2 prongs whereas the sierra ones round pluged
and it's not even as if you can chop the ends off and swap them around either
The abs sensors are still aveable from ford front and rear.I got 2 front ones from ebay for the 2wd cossie which where the right ones with correct part.Also i had some for the v6 sierra which are spot on for the cossie but the only diffrence was the length !!!!
i was in seeing my friendly parts man to get all new bolts and nots for the rear beam and suspension,he was genuinely interested in what i was doing to the car,he did a search and they are no longer available for the 2wd according to his computer.which ebay seller did you get them from,i might just buy them and be done with it if they are any use.
dojj
1 X NEW FRONT ABS SENSOR
TO FIT
FORD SIERRA COSWORTH 2.0 1987- 1989
NOTE - HANDED, AFTER BUYING PLEASE STATE WHICH SIDE YOU NEED
IMAGE FOR ILLUSTRATION ONLY
TO FIT
