Set up's
Old 04-01-2009, 02:21 PM
nice_head
nice_head's Avatar
Default Set up's
Just wondering how often peeps get there cossie's set up i.e RR or Mapped? Mine got done almost 2yrs ago and its still running fine (fingers crossed lol) so I was just wondering if its worth getting it done again.
Old 04-01-2009, 02:23 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
It doesn't hurt to get it det-checked once a year..
Old 04-01-2009, 05:26 PM
xr_craig
xr_craig's Avatar
For what a check up would cost mate it's worthwhile just for peace of mind.
Old 04-01-2009, 05:58 PM
LHD220Turbo
LHD220Turbo's Avatar
IMO providing your spec isnt anything wild there isnt a great need to have it mapped or rolling roaded
as an example; if you running stage 3, t34.48, greens, 500 cooler, 3 map sensor, standard engine. providing you have a decent chip in it, say MSD as an example, or any other decent chip you dont really need to get it set up. Provding the CO is set at idle it should be plug and play.
as ever tho; i would recommend having and afr gauge and maybe get the fuelling checked on wideband
i would only ever go for a live map if my spec was different to the norm
if you can afford a live map (Ł500 ish) then of course this is the best available and cannot be faulted, but i dont think its necessary in most cases
Old 04-01-2009, 06:02 PM
LHD220Turbo
just to have the car checked over i think MSD charge Ł150 + VAT and MA Developments charge Ł175 + VAT - dont quote me tho, prices on there website
live map is around Ł500 at MSD i believe
a rolling road run varies quite a bit depending on which rollers/ company you use - expect to pay Ł100 minimum, sometimes less, sometimes more
Old 04-01-2009, 06:15 PM
costina
Live long and prosper!!
costina's Avatar
It says in your sig 353bhp on what injectors is that?? i'm guessing light blues or blacks
if on greens your really pushing it on top end fueling tbh so be carefull
Paul
Old 04-01-2009, 07:43 PM
xr_craig
xr_craig's Avatar
I took mine to well lane and it was Ł120. For that it went on the rollers and had everything checked and the boost turned up a little.
I'd rather pay that to know it's fueling ok than pay however much for a rebuild
Old 04-01-2009, 09:51 PM
nice_head
nice_head's Avatar
Paul
There greens m8
Old 04-01-2009, 10:30 PM
Jimboxr4x4
Jimboxr4x4's Avatar
Very wise IMHO. The cost of a set-up is so little and is always money well spent.
Old 04-01-2009, 10:51 PM
costina
costina's Avatar
There greens m8
I'd get it checked sooner than later m8 thats a bit high for greens imo
have u any other mods ie cams etc and what rollers gave you that figure?
They are on there max and really no room for error
seen myself 344 and 346 on rollers and they started to get lean at the top
Paul
Old 05-01-2009, 07:06 AM
Jay,
Sponsor
Jay,'s Avatar
take it to tommy fields (field motorsport) hes in essex
Old 05-01-2009, 08:22 AM
olek
olek's Avatar
i would check the car at a RR it something big has happened in the engine-spec. bigger turbo, diffrent manifolds or something.
however, i do take the Innovate LM-1 lambda for a spin 3-4 times a year, just for a piece in mind...
Old 05-01-2009, 10:26 AM
costina
costina's Avatar
mines in my car always
Old 05-01-2009, 11:42 AM
DaveCrack
DaveCrack's Avatar
+1
Old 05-01-2009, 06:54 PM
olek
olek's Avatar
the LM-1?
Old 05-01-2009, 07:30 PM
nice_head
nice_head's Avatar
Paul
Just a standard engine with GRP A headgasket and stage 3 bits
I know im gonna get ripped for saying this but it got RR at Engine Advantages
So how much are light blue injectors this days then and wot sort of power gain can I expect from them?
Old 05-01-2009, 07:32 PM
KSA-Cossie
KSA-Cossie's Avatar
Get some siemens ones m8.
Old 05-01-2009, 07:33 PM
LHD220Turbo
if its been RR'd at EA, i doubt it made 353hp!
you're better of going for greys or siemens blacks injectors
you wont get any more power unless your engine & turbo spec can handle the extra power - the injectors would just supply the right amout of fuel at the correct moment
Old 05-01-2009, 07:34 PM
cossiedave
cossiedave's Avatar
here we go just leave the block alone
Old 05-01-2009, 07:46 PM
DaveCrack
DaveCrack's Avatar
the LM-1?
Got the Stack Lambda gauge with wideband sensor.
Old 05-01-2009, 08:15 PM
costina
costina's Avatar
TBH tuners cannot please everyone and people have there favourites so nuff said
imo 353 on greens is a bit much can be done with a bit more fuel pressure but watch for fuelling issues
lights blues are expensive really you need 55lb blacks and a new chip with about 28psi held could see around 370+
Paul
Old 06-01-2009, 09:27 PM
nice_head
nice_head's Avatar
Ok lads cheers for the advice, im gonna get it booked for a RR as soon as
Old 06-01-2009, 09:32 PM
costina
costina's Avatar
All the best fella hope u get it sorted
Paul
Old 07-01-2009, 04:59 PM
AndyPen
AndyPen's Avatar
I had mine rechecked after changing the exhaust and was glad I did as the fueling had changed. I also gained 30bhp
Old 13-01-2009, 09:36 PM
an1mal_69
an1mal_69's Avatar
Had my 2WD for a couple of weeks now..it was a fresh rebuild having covered a couple of thou..the bloke said he'd not had it set-up yet since running in but he'd consciously tried to keep it under 4k rpm..i too have continued this trend.
The spec is as follows;
200 block oversized 1.0mm
mahle pistons, std compression ratio
ARP rod bolts
high flow oil pump
Arp stud & nut kit
std cams
MSD chip
Turbo Technics T34, .63 housing
cant remember what colour the injectors are, will check in the light.
car is currently running @ 20psi, i know its dependent on the injectors, but what could i be expecting to see with a proper set-up, or would a base tune suffice..??
cheers, Nik..
Old 14-01-2009, 07:06 AM
LHD220Turbo
ARP rod bolts
high flow oil pump
Arp stud & nut kit
std cams
MSD chip
cheers, Nik..
assuming you have a decent intercooler, i'd be expecting to see 380bhp with similar torque with that spec - as you say it depends on injectors, if the are green 803's (most common injectors in stage 3) then you wont want to push it pass 350ish as you run the risk of laxing the injectors out = runs lean and engine goes pop
it all depends on what injectors you have to be honest
Old 14-01-2009, 01:45 PM
an1mal_69
an1mal_69's Avatar
sorry, forgot to say..has a front mount cooler yea.
Jus checked the injectors, they are green. So its a good idea to keep the boost down at 20psi then..??
Old 14-01-2009, 01:50 PM
LHD220Turbo
20 psi is about 1.3 bar i think, so i think you could increase it a bit more than that
for your set up i'd be expecting to see a boost spike of about 27psi and hold 23psi - which should see approx 330-340hp
i guess you know how to increase the boost?
i'd recommend you get the fuelling checked on wideband though
gambo08
04-02-2016 10:49 PM
martynhomer01
01-10-2015 12:05 AM
Alloy wheels and ICE for sale
28-09-2015 06:19 PM
20/20 vision
28-09-2015 03:03 PM
28-09-2015 10:05 AM
Quick Reply: Set up's
