Help!!!!!!!!!!!!
Help!!!!!!!!!!!!
right just been to fill up the car for later and as ever with a cossie it's started playing up,
i pulled on to the duel c way n gave the car some beans in 3rd changed in to forth n went to do the same in 4th but the car felt really sluggish, was having a real job boostin up!
i backed off limped home, ive just popped the bonnet to c if i have any sort of leaks but i cant find a thing, any 1 got any ideas?
if you just filled up, it might be shitty fuel? that would give you the symptons your describing
did you use a different fuel?
i always use v power (99 ron) in mine; but i couldnt get any this one day, as i was low i had to use BP ultimate (97 ron) and the car felt as if it had problems boosting, so much so i thought i had developed a problem
yer i had just filled up, from the same shell station i use, v-power as usual,
