Fuel line removal
Old 14-06-2008, 02:58 PM
cosrep
cosrep's Avatar
Default Fuel line removal
How do I remove the fuel line from the fuel rail on a 1990 2wd, the one that has a chrome circular fitting with what looks like a spring on the inside..? Dont want to force it and break it.
Old 14-06-2008, 03:58 PM
dazzle740
dazzle740's Avatar
sorry mate but the removal of the the fuel line from the rail requires a special tool i had my local tuner do mine
Old 14-06-2008, 04:26 PM
The tool is a air con pipe disconnector of the relevant size, it comes either hinged or in two parts but wraps around the pipe then you push it into the connector and it expands the wire ring inside so you can pull it apart, as I say these are used on air con fittings as well.
ebay might be worth a go.
Old 14-06-2008, 04:49 PM
RS SHAUN
RS SHAUN's Avatar
i used a jubilee clip with the nut cut off, it worked fine
Old 14-06-2008, 04:57 PM
mechanic28
mechanic28's Avatar
this ind of worries me!as i only have a jubilee clip holding the fuel line to the rail!the previous owner must of binned the o.e fitment
Old 14-06-2008, 06:15 PM
LHD220Turbo
LHD220Turbo's Avatar
this is what you'll be needing
http://www.justoffbase.co.uk/Air-Con...=9&category=90
Old 14-06-2008, 07:58 PM
cosrep
cosrep's Avatar
Thanks for all the replies, I got it done this evening with the jubilee clip trick but ordered a set of air con disconnects for the future
1300gt
07-09-2015 12:06 PM
muffster
13
03-09-2015 09:40 PM
3doorcozmess
21-08-2015 11:17 AM
RSMK4TURBO
13-08-2015 08:06 AM
muffster
12-08-2015 08:14 PM
Quick Reply: Fuel line removal
