3dr tca's
Old 25-03-2008, 09:15 PM
JoeRS22
JoeRS22's Avatar
Default 3dr tca's
hey peps been working on the three door again tnt and started to remove the tca mounts inner and outer but came accross a hitch, the mounts that go onto the chasis legs one of the bolts has been replaced for a 10mm thread nut and bolt but do you think i can access this from the floor pan inside the car???
Old 25-03-2008, 11:13 PM
AndyPen
AndyPen's Avatar
Do you mean the arb mount mate?
Old 26-03-2008, 03:32 PM
dojj
Resident Wrestling Legend
dojj's Avatar
sounds like it
there are vents in the floorpans that give you access to these area's, you may need to chop them out but they will do the trick
most likely that the orignals hve snapped inside and thats the only way to get them out
Old 26-03-2008, 08:33 PM
JoeRS22
JoeRS22's Avatar
sorry guys done me homework today and realised i dont know what im talking about its actually the anti roll bar that fits onto the chasis rails, this must be common cause i remember me old 3 door had the same bolt replaced but they cut the chasis rail out and re-welded after fitting bolt (not cool)
Old 27-03-2008, 04:31 PM
cossie604
cossie604's Avatar
When mine stripped out, insted of using a nut and bolt I bought a set of arb mounting bolts for a granada...next size up but still with a 13mm spanner head. Just drilled and tapped out the captive nut to suit.
Old 28-03-2008, 08:29 AM
AndyPen
AndyPen's Avatar
Its possible for a really skilled welder to weld onto the stub - the added advantage being that the heat loosens the rust as well. I'd go through the floor and repair it with an inspection panel kind of thing. Just my view as it will be out of sight
Old 28-03-2008, 10:17 PM
JoeRS22
JoeRS22's Avatar
done the job now, brute force and bent the bracket down removing the old bush and inserted the lovely polyurethane item sorted...
Old 28-03-2008, 10:22 PM
bad boy rs
bad boy rs's Avatar
You animal! Lol!
Old 28-03-2008, 11:00 PM
AndyPen
AndyPen's Avatar
Where there is a will there's a way - glad its sorted mate
Old 29-03-2008, 06:25 PM
bad boy rs
bad boy rs's Avatar
Oi gaz you on my user name Ban him
Old 29-03-2008, 09:38 PM
JoeRS22
JoeRS22's Avatar
carefull bad boy rs gaz will get his kitchen devils out to you.......
Old 29-03-2008, 10:11 PM
Gazzonator
Gary Krishna
Gazzonator's Avatar
Theyre out and looking sharp!!
Old 30-03-2008, 07:35 AM
paulfreeman
paulfreeman's Avatar
You boy's need to get your motors on the road so i can anillate you on the strip at Santa Pod
Old 30-03-2008, 09:53 AM
bad boy rs
bad boy rs's Avatar
Fuck me the whole crew are on here, im gona move to another forum
Old 30-03-2008, 07:21 PM
JoeRS22
JoeRS22's Avatar
Wow hopefully it will smell better now.......
Old 30-03-2008, 07:25 PM
JoeRS22
JoeRS22's Avatar
Default You think your good then huh?????
just make the most of it cause when im back on the road you will be in me rear view mirror permanantly!!!
Old 30-03-2008, 07:32 PM
redcossie
redcossie's Avatar
what like you did to me not, on the way to ace:c ontent:
Old 31-03-2008, 01:56 PM
The Youth.
The Youth.'s Avatar
what an horrendous bodge, don't be suprised if you hear clonking at the front under load as the anti roll bar moves about as it won't be clamped as well as it should.
get the job repaired properly!!
steve
Old 31-03-2008, 09:06 PM
JoeRS22
JoeRS22's Avatar
oooooh sorry steve! maybe youd like to come down and fit it for me.........
Old 31-03-2008, 09:28 PM
Gazzonator
Gary Krishna
Gazzonator's Avatar
I dont know. These bloody weekend mechanics!
Old 31-03-2008, 09:35 PM
JoeRS22
JoeRS22's Avatar
least i dont take all day to fit a fuel tank!!!! your not at seat you know...
Old 01-04-2008, 06:53 AM
paulfreeman
What do you reckon on this manifold: it had cracked and has been rewelded at the 'flange' where it bolts to the turbo.
http://www.pistonheads.co.uk/sales/439744.htm
yatta
21-05-2016 10:31 PM
Sierrasideways
08-10-2015 06:37 PM
martynhomer01
01-10-2015 12:05 AM
IainRS1700T
25-09-2015 06:44 AM
Mark V8
13-09-2015 09:34 AM
Quick Reply: 3dr tca's
