are 2wd and 4x4 cosworth front shocks the same diameter
Old 03-02-2008, 07:32 PM
155lee
155lee's Avatar
Default are 2wd and 4x4 cosworth front shocks the same diameter
as title,are they the same diameter where they push into the hub?i have aset for sale on ebay and somebody says the 4x4 hub hole is bigger?cheers,lee
Old 03-02-2008, 08:06 PM
jon@work
jon@work's Avatar
different
Old 03-02-2008, 08:11 PM
SillyFezzaMk1
Rubber Rhino Crew
SillyFezzaMk1's Avatar
I just measured mine today and 2wd are about 45mm and 4x4 about 50mm in diameter.
Dan
Old 03-02-2008, 08:13 PM
IainRS1700T
IainRS1700T's Avatar
Yup 4x4 are bigger - by a mm or two.
I came by some lovely leda remote resevoir coilovers only to find out they dont fit my hubs - the 3dr ones are def smaller.
Iain
Old 03-02-2008, 08:26 PM
SillyFezzaMk1
Rubber Rhino Crew
Iain
OMG you must be my long lost twin....
I have remote res leda coilovers in 4x4 size but want to run 2wd hubs so i've got a dialemma....hence the measuring today.
What did you do...fuck the ledas off?
Dan
Old 03-02-2008, 08:44 PM
155lee
155lee's Avatar
i once had a v6 cossie sierra i built,i wanted to use a cossie arb,so i had to use cossie track control arms,the pin that goes through the hub on a normal sierra is totally different,so i used xr4x4 hubs with the cv joint from a 4x4,i just removed the driveshaft.it worked well,maybe if you are determined to use the leda gear you could do this!cheers,lee
JoeyBoyden
04-01-2024 02:36 PM
14-08-2015 07:29 AM
dal3door
13-08-2015 06:55 AM
adam151082
11-08-2015 04:50 PM
Quick Reply: are 2wd and 4x4 cosworth front shocks the same diameter
