easy way taking rear springs out ???
Old 02-08-2007, 10:28 AM
DAN P
DAN P's Avatar
Default easy way taking rear springs out ???
as abover really can you do it with out cutting the springs and droping rear beam 2wd saff
thanks for any help
Old 02-08-2007, 11:22 AM
J9BBY
J9BBY's Avatar
You can get them off by taking bolt out from top of shocks, unbolting ARB, disconnecting rubber brake lines and using spring compressors.
This worked well for me as i was putting braided lines on anyway. I'm sure other people will have other suggestions.
Pete.
Old 02-08-2007, 11:41 AM
I have done lowered springs by just levering out after disconnecting shock, from the bottom of the spring, stand on the arm and push down as you do it.
Old 02-08-2007, 11:49 AM
DAN P
DAN P's Avatar
nice one lads i thought it was a 2 man job undone shock done anti roll bar the spring does half come out just need some one to stand on the arm them
Old 02-08-2007, 05:42 PM
saff cosworth
saff cosworth's Avatar
easy
Old 02-08-2007, 09:42 PM
Received 1,044 Likes on 998 Posts
I changed them on my old sierra buy dropping the shocker bolts off removing the brake flexy pipes n had a big long bar n leavered the arm down.
Old 02-08-2007, 10:48 PM
TurboFlush
TurboFlush's Avatar
droping the rear beam is not that hard. I normally just unbolt what I need to let the rear arm swing down. a little force is needed to help it down the rest of the way to get the spring out. sometimes droping the rear beam can help. dont have to be droped much.
should try doin the front springs on a mustang if you think that is hard.
TF
shortie
19-08-2015 01:01 AM
dal3door
13-08-2015 06:55 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: easy way taking rear springs out ???
