Saffire dashboard replacement - will the "facelift"
Old 09-06-2007, 09:24 AM
TurboShed
Cossiemodo
TurboShed's Avatar
Default Saffire dashboard replacement - will the "facelift"
Will the facelift dashboard just slot in? Upper and lower?
My dash is a mess (holes from old immobilisers, car phone holes, broken glovebox mount, etc. it's hideous).
It's a 1991 H plate 4x4 Saff BTW.
Old 09-06-2007, 11:01 AM
jaimesdna
jaimesdna's Avatar
yes
Old 09-06-2007, 01:35 PM
iansoutham
OCD Victim
iansoutham's Avatar
It will just slot in, but you will have to possibly change things like the heater control unit as it may be different and possibly a couple of other little odds and sods.
Dojj is the best person to ask as he has done this many a time.
Old 09-06-2007, 04:52 PM
Daveysaff
Skint Passionford User
Daveysaff's Avatar
I've got a prefacelift lower dash for sale if you're interested?
Ł20 delivered?
Old 09-06-2007, 05:30 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Ł20 delivered?
Actually yes I am interested, I'm in Liverpool so perhaps you could drive it over the water and meet me somewhere? I'd prefer that over the hassle of post/courier etc.
Old 10-06-2007, 09:10 AM
dojj
Resident Wrestling Legend
dojj's Avatar
if you've got a 91 spec car and waht to fit the 92 spec dash in to it then there are no major problems, as long as you rememebr that there are slight differences in the instrument cluster (it's just slightly smaller) and that the plastic clip on the left hand side of the vent isn't broken
if you have a pre 90 spec dash there is a lot of fucking about and you basicly have to use every single bit from the newer dash if ytou want to swap over, including the steering column and all sorts of other stuff you wouldn't even think of, even the slider controls on the vetilation side of things as well as the amp casing and the lower kick panels
the good things baout it is that the switches for the fogs and screens use the same plugs for any of the post 97 cars
the lower portion is different but only slightly on the 91 and 92 cars but it's totaly different on the pre 90 spec cars
also the fittings for the centre console are different on the pre and post 90 cars as the screw holes are further back on the older versions
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Quick Reply: Saffire dashboard replacement - will the "facelift"
