steering coloum
Old 23-02-2007, 03:50 PM
nik t
nik t's Avatar
Default steering coloum
does anyone have the problem of the coloum dropping when
driving,how should i say spirited.
anyone know what has to be done up to solve this?
Old 26-02-2007, 01:11 PM
cozmeister
More boost Igor!
cozmeister's Avatar
New column bushes
And, if it's adjustable, check that the locking latch for the adjustment lever is working properly.
Old 26-02-2007, 01:24 PM
nik t
nik t's Avatar
Is adjustable.
just not locking tight.
Old 26-02-2007, 05:09 PM
So you need it to tighten more, see if you can slip a thin washer on the through bolt to handle to give more tension, when handle is tightened so it has more pre load if you like.
Old 26-02-2007, 06:28 PM
nik t
nik t's Avatar
will give that a go the weekend
thanks
Old 27-02-2007, 12:15 PM
No probs hope it works ok.
tankybaby66
06-02-2016 02:24 PM
07-10-2015 12:56 PM
IainRS1700T
25-09-2015 06:44 AM
dange
Ford Mondeo Including ST
23-09-2015 12:11 PM
dirtysteve
Ford Focus ST
16-09-2015 05:29 AM
Quick Reply: steering coloum
