Boost spike - what causes it? How can I cure it?
Old 29-01-2007, 02:31 PM
Paulo P
Paulo P's Avatar
Default Boost spike - what causes it? How can I cure it?
I'm just wondering what causes boost spike?
My 2 wheel drive Cosworth sometimes spikes the boost up under load It's hard to describe but in higher gears it boosts up 1.3 bar and blows out the spark I don't mind a spike as long as the boost comes down to the preset limit if you know what I mean.
I re-gapped my plugs to 0.6mm because they were gapped at 1.1mm and it still did it and I've now fitted a Group A coil but I haven't tested the car yet.
My car now has a -31 actuator on it and it holds 1 bar/15psi nicely but sometimes it spikes and you have to back off and then apply the throttle again, it also did this as standard with a standard actuator.
Would adjusting the actuator rod either way control the spike? I thought that it would but I wanted to check before adjusting anything
This afternoon I am going to check the vacuum hoses and make sure they are all tight etc but I want to make 100% sure the car is A1 rather than just trying to get around the problem.
Sorry if this post is hard to understand
Thanks
Old 30-01-2007, 09:04 AM
TurboShed
Cossiemodo
TurboShed's Avatar
Very small jubilee clips are real good for making sure those vacuum pipes are tight, mine used to come off all the time.
Old 30-01-2007, 10:35 AM
Paulo P
Paulo P's Avatar
I went around under the bonnet last night fitting clips where they were needed None of them have come off though.
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Boost spike - what causes it? How can I cure it?
