Fuel Pressure Regulator
Hi!
How much can the fuel pressure be increased on the standard
4x4 Sierra fuel pressure regulator?
regards
Mathias
regards
Mathias
Hi,
Increasing is : basic pressure fuel pump (3,5 bars) + boost pressure.
ie : if boost pressure is 1,5 bar (22 psi) , total fuel pressure will be
1,5 + 3,5 = 5 bars (75 psi)
It's reason because fuel pump capability and good wiring are very important.
Regards
Claude
Regards
Claude
HI Claude!
I know what you mean, but I´m interested how much I can
increase the fuel pressure with the top screw?
What I have learned is that the original fuel pressure regulator
is set to 3 bar with vacuum pipe unplugged.
How much can I increase the pressure when I make some turnings
on the screw on the top?
regards
Mathias
regards
Mathias
Originally Posted by Mathias
HI Claude!
regards
Mathias
regards
Mathias
Your tuner know exactly your new set up fuel pressure.
Anyway, if you have no info about, check and no change is recommanded.
Regards
Claude
HI!
Made now some measurements on the pressure regulator and
found out that it´s adjusted to appr. 2,9bar with pipe unplugged.
In wich direction do I have to turn the screw to increase it to 3,5bar?
regards
Mathias
regards
Mathias
HI!
regards
Mathias
regards
Mathias
HI!
Made now a "calibration" with a WIKA pressure test equipment.
A 1/4 turn on the screw changes the pressure already alot so
it´s not so easy to set it on 3,5bar.
regards
Mathias
regards
Mathias
HI!
regards
Mathias
regards
Mathias
HI!
Why was the new regulator set on 2,9 bar? Was it with pipe
unplugged?
Between 3,5 bar and srew full turned (nearly 5 bar) there is
max. a 1/4 to a 1/2 turn on mine...
regards
Mathias
unplugged?
regards
Mathias
HI!
unplugged?
regards
Mathias
unplugged?
regards
Mathias
SMILER258
28-09-2015 09:04 AM
Dubs44
19-09-2015 06:31 AM
