cosworth engine wont idle
hi
just having a few probs getting my rebuilt standard cossie engine to run right , fires up ok but wont idle and it seems to be running rich (black smoke) i have checked and cleaned idle control valve and is ok ,i have 3.5 bar pressure at the rail , what is the next thing i should be checking or changing ??
cheers
cheers
cheers for that mark i will check through and see if that sorts it out
ant found out water temp sen not connected and when connected it will not start full stop will run without it but cut out as soon as it s connected
https://passionford.com/forum/viewto...asc&highlight=
this was me in your position the other day mate
hi
i want to double check the wiring to my map sensor and tps sensor to make sure plugs have not been mixed up ,anybody know what colours should be a which sensor ??? then i am waiting on a new temp sensor to try and struggling to find a 2bar map to try in place of the old one ,so if anybody has one available pm me
cheers ant
cheers ant
the map sensor wiring should be 3-core with braided shield - TPS wiring is 3 separate wires
as stated above, sounds like either water temp sensor, or map sensor
if you have run the engine for a good few minutes in this condition, check the oil - it'll probably be piss thin from all the fuel in it, and worth changing
cheers for that the wiring is correct and i tried a new water temp sensor today and made no change , so i ll wait till i get another map sensor hopefully that will be it , then change the oil
ant
ant
hi
i now have the engine running ok after fitting another map sensor , but it will only run if the water temp sensor plug is not connected puffs a bit of black smoke out still a bit rich i guess , but every time i connect the sensor it cuts out it is a brand new sensor , so could it just be a duff one or should i be lookin else where to sort the problem??
cheers for any ideas
ant
ant
Could be a duff sensor, or the wiring to the sensor.
Coolant Temp Sensor Checking - info courtesy of Simon @ SECS
1) Ensure ignition is OFF.
2) Remove rear of ecu plug cover and insert plug back into ecu.
3) Turn ignition back on (do not start engine)
4) Check resistance between pins 29 and 11. Should be 800 to 5000 ohms (depends on temp). If outside this range, check sensor and/or wiring.
hi
hmmm still strugglin trying to get the water temp sensor plug connected with out the engine cutting out , my 12v tester will not measure ohms, so i have tryed 2 other sensors and still gives the same problem , i belled out the cores and they seem to be intact to pins 29 and 11 , allso noted that pin 11 is linked to the tps and cats sensors ,even with no other sensors connected bar the water temp it still stops the fuel pump from priming before start up normally 2 to 3 secs without water temp connected with it .5 secs ! so any other ideas are welcome
cheers ant
cheers ant
hi jon
yea i used the pics posted on here a bit back for referance , set just to the outside edge of the lug ,and both pullys with pointers level with dizi lined up to the mark , i cant even start the car with temp sensor connected so im thinking it is somthing electrical but have no idea what ?
cheers ant
cheers ant
TPS Checks
2) Remove rear of ECU plug cover and insert plug back into ECU.
4) THROTTLE CLOSED:
4x4: Check for DC voltage less than 0.5V between pins 11 and 17.
2WD: Check for DC voltage greater than 4.5V between pins 11 and 17.
5) THROTTLE FULLY OPEN:
4x4: Check for DC voltage greater than 4.5V between pins 11 and 17.
2WD: check for DC voltage less than 0.5V between pins 11 and 17.
4) THROTTLE CLOSED:
hi
engine/box/loom and ecu were bought from a written off 2wd , after getting engine checked over was advised to have bottom end rebuilt , i belive the ecu is the L6 with the white mixture screw , the engine bay loom i got all looks in order with no mods done to it still in original wrapping/taping
ant
ant
Do the injectors and MAP sensor match the chip ? Have you looked inside the ECU to check that the chip is the one you were expecting it to be (ie that it wasn't changed by the previous owner) ?
What car have you fitted the engine/ECU/loom to ? Are you sure the wiring is OK in the car (no dodgy ECU voltage issues) ?
hi jon
it came with yellows/2bar map sensor and i had a look inside the ecu at the chip , numbers stamped on it 88741s , m2764a-4f6 , pgm 12.5v then a small sticker on it says 45, L2o , 67 looks like the standard one , and on the ecu cover it has w45.06/L20-67 (now not sure if it is an L6 ecu ?) the engine is now in a kitcar and i have wired up the bay loom as ,
Red-Blue wire to Battery Feed
Green wire to Tacho
Black-Red wire to Fuel Pump
Black wire to Ignition Switch
Brown-White Wire to Temp Gauge
i have double checked the wiring and all appears in order , how do i check for dodgy ecu voltages ?it gets over 12.5 volts from batt supply and ignition switch, i did check for voltage at water temp sensor plug and it read 4.5 volts not sure if this is correct , any more things i can try feel free to let me know
cheers ant
Green wire to Tacho
cheers ant
have checked behind rubber boots on water temp sen and cats nothing out of place ,checked other plugs allso , checked ecu plug all wires in place, so i can only think of gettin hold of another ecu to try or gettin an auto electrician ?
ant
ant
not to sure about that , i guess i would need to get a vac gauge or something like to check it with , i still cant get past the turning on the igniton stage without starting engine for it to happen each time the water temp sen is connected it wont start with out it does have tried connecting one core of water temp wire at a time the pin 11 cable is ok its when the pin29 cable is connected it kills it , so i ll have to try and get hold of a similar ecu to try and see if that makes any change , anybody got one forsale ??
jon
i never saw engine running as it was already stripped from donor car when i got it , we did adjust co screw 2 turns up and then down due to it running so rich then realised the water temp sen was not connected up ,then that is how i realsed this fault , im based in stockport /mcr
ant
ant
nothing more to report yet im gonna see if i can get my ecu checked by collins just waitin for a reply to see if they can do that or not , if not then i will get hold of another ecu and try that, i cant be that far off from sortin it as i feel like ive checked most things out so far , so ill let you know what happens
ant
ant
so the ECU is OK
the chip you've got is "adequate" and matches the map sensor and injectors
that leaves the wiring loom, or sensors, or sensor gaps, or a mechanical issue
you're happy that the cam timing and dizzy timing are correct, and that the crank sensor and phase sensor gaps are OK (0.6-1.0 and 0.2-0.3mm respectively IIRC)
the map sensor (and its wiring) was checked (by replacement), the TPS seems OK, the water temp sensor was checked (by replacement), the fuel pressure has been checked (with the vacuum pipe disconnected and plugged)
check the temp sensor wiring - pull back the boot and give the wires a good tug - you may have continuity, but still have a duff wire
have you done a compression test ? a bent valve or 2 may cause the same syptoms (foot on the accelerator peddle, count to 5 with HT lead disconnected) Watch the speed that the compression gauge increases to max - if a bit jerky, pull the head off and get the valves replaced, if compressions not roughly equal between pots, again get the head off.
below is the complete guide, from which I've posted a couple of what I thought were relevant items above
BASIC FAULT FINDING GUIDE FOR COSSIE ECUS by Simon @ SECS
NOTE: Some of these results can be affected by an alarm system or immobilizer. I have assumed the car has a 2.5 bar/3.0 bar map sensor.
If SECS monitor is fitted, unplug it! (A faulty monitor or incorrectly fitted can cause engine not to run)
4) MAIN POWER CHECK: Check for DC voltage of at least 11.5V between ecu pins 19 and 20.
5) REFERENCE CHECK: Check for DC voltage of around 4.8 to 5.2V between pins 11 and 30.
6) MAP SENSOR CHECK: Check for DC voltage of approx 1.8 to 2.5V between pins 11 and 15.
7) THROTTLE CLOSED:
8) THROTTLE FULLY OPEN:
9) Turn ignition off, unplug ecu, and turn ignition back on (don’t forget immobilizer if fitted)
10) CRANK SENSOR: Check resistance between pins 3 and 4 between 300 and 1200 ohms.
11) CRANK SENSOR: Check AC voltage on pins 3 and 4 while cranking engine - should be at
least 2V.
11) PHASE SENSOR: Check resistance between pins 5 and 23 between 300 and 1200 ohms.
12) PHASE SENSOR: Check AC voltage on pins 5 and 23 while cranking engine - should be at
least 1.5 - 2V.
12) INJECTOR: Check resistance from pins 18 to 20 should be 2 to 5 ohms.
13) INJECTOR: Check resistance from pins 35 to 20 should be 2 to 5 ohms.
14) INJECTOR: Check resistance from pins 33 to 20 should be 2 to 5 ohms.
15) INJECTOR: Check resistance from pins 32 to 20 should be 2 to 5 ohms.
NOTE: INJECTOR TESTS MAY NEED MAIN RELAY ENERGISED ON L1 and L6 ecus (link pins 1 and 10 first)
16) IGNITION TRIGGER: Read voltage between pins 24 and 25, should be at least 4.5V.
17) IGNITION TEST: BEWARE DANGEROUS VOLTAGES ON PLUG/COIL LEADS.
Quickly link pins 24 and 25 on and off this will FIRE the ignition coil. Rotate dizzy by moving car in gear to point rotor arm at one plug lead and remove spark plug (earthing it on chassis or engine) to see spark. Try for each plug in turn. Or remove king lead at dizzy and place end within 1 centimetre of earth to see a big spark.
18) Place a temporary wire link from pin 1 to pin 10 (energises ecu power relay) - you should hear a click.
19) Quickly link pins 19 to 28 to test fuel pump runs.
20) COOLANT TEMP: Check resistance pins 29 and 11 for 800 ohms to 5000 ohms (depends on temp)
21) CHARGE TEMP: Check resistance pins 31 and 11 for 800 ohms to 5000 ohms (depends on temp)
Unplug the ecu and turn the ignition on. If the fuel pump runs the relay has been wired to run permanently or the relay is jammed.
However, if the pump is running continuously, this WILL NOT stop the car from starting.
Some chips don’t drive the fuel pump relay output properly as this is used for other features like ALS etc.... (PECTEL/AHMED chips mainly). In these situations, the pump is rewired to run continuously.
If however, the pump is wired correctly and working properly, if it runs continuously when the ecu is plugged in only, then the ECU and/or chip may have failed.
The pump is ok to run continuously
7) THROTTLE CLOSED:
least 2V.
least 1.5 - 2V.
good stuff jon i ll get together the bits i need and start checking at weekend, i guess i ll need to getanother volt tester that measures ohms , ill see how it goes
cheers ant
cheers ant
hi jon
story so far
4) MAIN POWER CHECK: Check for DC voltage of at least 11.5V between ecu pins 19 and 20. = 13.17VOLT DC
5) REFERENCE CHECK: Check for DC voltage of around 4.8 to 5.2V between pins 11 and 30. = 4.95VOLT DC
6) MAP SENSOR CHECK: Check for DC voltage of approx 1.8 to 2.5V between pins 11 and 15. = 2.14VOLT DC
7) THROTTLE CLOSED:
2WD: Check for DC voltage greater than 4.5V between pins 11 and 17. = 4.78VOLT DC
2WD: check for DC voltage less than 0.5V between pins 11 and 17. = 0.6 VOLT DC
10) CRANK SENSOR: Check resistance between pins 3 and 4 between 300 and 1200 ohms. = 667 OHM S
least 2V. = 0.02 VOLT AC (MAY HAVE A PROBLEM HERE?)
11) PHASE SENSOR: Check resistance between pins 5 and 23 between 300 and 1200 ohms. = 778 OHM S
least 1.5 - 2V. = 0.4 VOLT AC ( COULD HAVE PROBLEM HERE ?)
12) INJECTOR: Check resistance from pins 18 to 20 should be 2 to 5 ohms. = 3.2 OHM
13) INJECTOR: Check resistance from pins 35 to 20 should be 2 to 5 ohms. = 3.2 OHM
14) INJECTOR: Check resistance from pins 33 to 20 should be 2 to 5 ohms. = 3.2 OHM
15) INJECTOR: Check resistance from pins 32 to 20 should be 2 to 5 ohms. = 3.2 OHM
16) IGNITION TRIGGER: Read voltage between pins 24 and 25, should be at least 4.5V. = 0.2 VOLTS DC ( PROBLEM ??) unless you mean measure when i try and start the car ? this is measured when ignition is turned on?
18) Place a temporary wire link from pin 1 to pin 10 (energises ecu power relay) - you should hear a click. (NO CLICK HEARD)
19) Quickly link pins 19 to 28 to test fuel pump runs. (TESTED OK)
20) COOLANT TEMP: Check resistance pins 29 and 11 for 800 ohms to 5000 ohms (depends on temp) = 880 OHM S
21) CHARGE TEMP: Check resistance pins 31 and 11 for 800 ohms to 5000 ohms (depends on temp) = 886 OHMS
looks like all is not as it should be with number 11 , 12 , 16 ,and 18 ??
tdc gap and phase gap , and test 17 will be tested tommorrow plus comp test as long as it turns up . so ill get these done
cheers ant
story so far
7) THROTTLE CLOSED:
cheers ant
big_Rad
15-09-2017 09:36 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
