gear box oil??
Originally Posted by saphc05
i use atf(auto transmission fluid) as the oil in the manual made my box whine a little has been in for about 12 months with no noises/problems
Location: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Originally Posted by 2001ode
Hi
2wd gear box oil finis code is : 5 014 519 (1 litre)
SQM2C 9010-A (Ford spec) Dexron BA
(same for power steering)
Regards
Claude
Regards
Claude
Bruce
sorry for the confusion its actually called hydraulic fluid used in auto boxes and pas systems red in colour cant remember finis number. a friend who's a service tech for tvr also recommends using this in t5 boxes
The T5 was originally run on ATF fluid, well a modified version of.
It is not uncommon for manual gearboxes to use an ATF. If you want a really good one have a look at the Amsoil Synthetic ATF.
http://www.opieoils.co.uk
Guy.
Guy.
Adam Graham
06-09-2015 06:04 AM
