cosworth problem
cosworth problem
hey,
my dad has a 2wd saph cos and for some reason whenever he puts his foot down and the turbo tries to kick in it seems to cut out and make the car judder... any ideas of what is causing this?
he has an aftermarket actuator on it (not sure what it is it came with the car) im thinking this may be the problem, but he thinks its somthing to do with the amal valve... any help will be apreciated
Disconnect the amal valve and see what happens,sounds like the boost protection in the ecu is faulty,does it start to boost then cut out at about 15 psi of boost ???????????
cheeRS stu
cheeRS stu
ive had a bit more info about the problem, it only does it in 1st and 2nd gear, its fine in all the rest
i dunno what kind of boost it cuts off at as he doesnt have a boost gauge (Car is pretty much standard)
Stu @ M Developments
41
21-08-2015 06:47 AM
