What type of spark plugs for cossie on green injectors??
i have since a month a 2wd cossie!
It runs ons green injectors and should do 330hp.
What type of spark plug do you recommend??
Also it runs on a t3, how much can do a stock t3 max??
and how do i recognize a modified t3??
Testing the future
i use the 071's. they don't last very long before they need gapping again as the electrode erodes quite quickly. but they're cheap enough to replace regularly
You dudes should really try out the Iridium plugs - they last ages - I paid $80 Australian for a set.
Every plug I tried - including the ones you have mentioned and an ngk v groove plug do not last very long or foul really easy.
The codes IRIWAY 8 or IRITOP 8 are defined as racing plugs (who knows what that means) and are a little hard to get (i.e. you have to order them) but are worth it.
Before using them every 10 or so drives in the Sierra I had to clean plugs or risk fouling them on startup.
I now that my car ran 11:1 rich on startup.
Will fix as I am now fitting a Pectel T2.
Cheers dudes (p.s. - I do not work for NGK)
Redumbdancy
LINCOLN - Iridium plugs are known to snap off very easily. Happened twice in quick succession to a guy i knows 600BHP Supra taking all the valves with it
Theres no doubting the performance improvment from them but there have been ALOT of cases that ive head of these plugs breaking.
Zoggon
10-08-2015 10:39 AM
