Sierra 4x4 Cosworth front right driveshaft problem
Every time when I turn left i feel judder on the front right side of the car when i want to move the driveshaft in direction inner cv joint it is impossible
on the left one it is a little way to move campared with the right one.
The right driveshaft can be longer as serial, do anybody know the dimension of the half shaft and the CV joints.
Must the cv joint's be the same on right and left.
I have [/img]
I have [/img]
check your exhaust is not catching anythink.
had exactly the same problem on my 4x4. the exhaust moved slightly when the engine got hot and fouled the front prop & chassis rail.
My tyre is rubbing but only on the side im having probs with, I dont think its the rubbing causing the vibrasion as its enough to bust my cv joints after only a few miles.
when i turn left i get a vibrasion from the front drivers side and it does not feel safe, we have try'd it at all speeds and even coasting at 5mph out of gear on a left turn you can feel it.
ive just finish'd getin all the bits together to give it a good going over
UPRATED Ford Sierra Cosworth Fan Switch. (Sensor)
COLLINS -31 ACTUATOR
RS Cosworth Bosch 803 "Green Injectors" x 4
3 bar MAP Sensor
4x4 cosworth PTS 330 bhp chip
FORD SIERRA COSWORTH RS500 Polished ALLOY INTERCOOLER
SIERRA & ESCORT COSWORTH RS 500 INTERCOOLER FITTING KIT
NEW TYRES ALL ROUND
POLY BUSHES ALL ROUND
25MM LOWERING SPRINGS AND KONI ADJUSTABLE SHOCKS front and rear
BRAIDED BRAKE PIPES
REAR CALIPERS
FORD COSWORTH SIERRA / ESCORT ARP HEAD STUD KIT
YBO611 GENUINE GROUP A HEAD & CAM COVER GASKET COSWORTH
SMOKED BOOST/ OIL PRESSURE GAUGE
SIERRA SAPPHIRE RS COSWORTH PILLAR GAUGE MOUNT DOUBLE
SUSPENSION UNIVERSAL BUMP STOP KIT
Sierra sapphire 4x4 Cosworth Uprated Poly Bush Engine Mounts
new driveshafts front and rear
full samco kit
Im hoping when i fit the new shafts and koni's and the engine mounts the problem will go away as them parts are the parts ppl have told me it might be, Ive got all new poly bushes to fit also to help solve the issue.
if i get the problem sorted i will post again
3 bar MAP Sensor
NEW TYRES ALL ROUND
BRAIDED BRAKE PIPES
REAR CALIPERS
full samco kit
JoeyBoyden
04-01-2024 02:36 PM
