fiesta rs turbo HYBRID turbo unit + standard turbo unit! + FSE POWER BOOST VALVE!
also have 2x t2 turbo units as spares, the one without the manifold is a hybrid t2 the other with the manifold is a normal t2, they have not been tested by me though! can post for £12 with DHL.
What's the hybrid part? Is it bigger exh housing on the T2?
I ask cause a T2 might be a little small for the engine i'll be running, but i want as little lag as possible.
there both the same housings, the hybrid will have a bigger thrust bearing, cant take more of a pounding etc......... you dont get hardly any lag from a t2
They might be a bit small for my need then, don't wanna run massive boost until in know what comp ratio with new pistons will be. For that reason, im out
