Ford Puma Discuss the Ford Puma here!
Engine problem
Old May 4, 2012 | 06:58 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Default Engine problem
I put my Puma up for sale on ebay this morning and then according to sod's law, the fucking thing shit itself on the way to work 5 minutes later
i was going up through 3rd gear and suddenly heard a noise like stripping teeth and i thought the cam belt had gone but the engine stayed running and wasn't particularly noisy or anything. i checked for FEAD belt, but that was all still there.
it idles ok and drives ok on light throttle up to 3000rpm or hard throttle at higher revs, although down on power. i'm thinking it might be something to do wit hthe variable cam timing, but have no idea about them and don't have a haynes manual to read up. i was going to take the cam cover off the top and have a look what i can see, but anyone else got any ideas or experience of similar things?
Old Jul 3, 2012 | 07:07 PM
foreigneRS's Avatar
foreigneRS
Testing the future
had the fault code reader on it and it said about cam timing, so think the actuator has gone. was low on oil, so that's a likely cause
anyone changed an actuator? just change the whole pulley?
any tips on special tools needed for cambelt etc?
Old Aug 1, 2012 | 06:35 PM
Shilly's Avatar
Shilly
no special tools needed to lock cams etc lot of 8/10mm bolts though
make sure when you are locking the pulleys up that the marking lines on the pulleys are parallel to the head
Old Aug 1, 2012 | 09:12 PM
foreigneRS's Avatar
foreigneRS
Testing the future
thanks for the tips
it's up for sale again now, so hopefully someone will take it off my hands so i don't have to bother.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
