Ford Puma Discuss the Ford Puma here!
Puma 1.7 missfire ???
Old Jun 13, 2011 | 05:24 PM
matts1's Avatar
matts1
Default Puma 1.7 missfire ???
Need help guys
1.7 Puma with a missfire on 1 & 4 only - no spark.
Coil pack, plugs and leads have been replaced wit new items
What next as we are stumped, figure the ecu could be at fault??
Old Jun 13, 2011 | 05:37 PM
foci's Avatar
foci
This exact same thing happened to my brothers 1.6 focus. Turned out to be the ecu. We only found out after we changed the coil and plugs as well. hope this helps
Old Jun 13, 2011 | 05:40 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
I don't know much about ecu's. could it be a wiring fault? or a faulty new coil pack, years back i had a 2.0 wide mouth frog scorpio, it was missing so replaced the coil pack still the same, after much head scratching took the coil pack back and swapped it for another and it was fine, I was unsure if the new coil pack was faulty so ford swapped it just to see and it was..
Old Jun 13, 2011 | 05:46 PM
Can you not take a plug lead off one at a time and stick a spark plug in the end of the lead to see if it is sparking ok.Do this for all 4.
Old Jun 13, 2011 | 05:55 PM
matts1's Avatar
matts1
Hi Glen, no spark on lead one and four, Matt, we did wonder about the coil pack as it is not a genuine ford item but a decent make so maybe that would be a first port of call.
Then we figured it is on to the ecu but that looks to be a nightmare of a job to get out!!
Old Jun 13, 2011 | 06:00 PM
24vcossiemat
mine was genuine ford and it was faulty so its possible but to be fair there is a lot more experienced people on here that will help I suppose, so I'll leave it to them to help you. good luck with it mate.
Old Jun 13, 2011 | 06:06 PM
I would take the coil pack back and try and swap it for another one.Im sure the 3 wires to the coil pack are 12v live a earth and a pulse live feed.Do you know anyone with a fiesta or a focus that you could just try a coil pack off.
Old Jun 13, 2011 | 06:55 PM
matts1's Avatar
matts1
Yes, 3 wires Glen, I have access to a 1.6 petrol focus, would the coil pack be the same?
Old Jun 13, 2011 | 07:39 PM
When my wifes Vreg 1.25 16v fiesta had a misfire i used my dads 51 reg 1.6 16v focus coil pack just to check it and it worked.Then i went to my local motor factors and bought a new coil.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
Ben26
Sep 3, 2015 07:55 PM
