Ford Puma Discuss the Ford Puma here!
Puma engine help?
Old Feb 23, 2011 | 08:43 PM
matts1's Avatar
matts1
Default Puma engine help?
After loosing its coolant my engine got fried today , it is a 1.7 puma on an x plate.
Thing is the engines seemt to be £££ and none local so wondered, can a 1.6 lump go in, and if so which one/year/model and what else needs to be changed ie box,ecu,wiring, mounts etc?
Can anyone help
Old Feb 24, 2011 | 12:44 PM
melinamotor's Avatar
melinamotor
Farpylee
What happened, did the core plug go?
Old Feb 24, 2011 | 03:52 PM
Dal_'s Avatar
Dal_
If you fit a 1.6 into what was a 1.7 car, you'll need to get busy with the wiring and ECU as the 1.7 has VCT, the 1.6 doesn't. Mounts should be the same as it's the same block.
Old Feb 28, 2011 | 08:48 PM
matts1's Avatar
matts1
Not sure where the water leak was, but very possible as it must have gone rapidly and the oil was not contaminated.
They have decided to try and sell it as is, less hassle for them so not to worry about replacing the lump, cheers for the info though peeps.
Ta
Matt
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
Ben26
Sep 1, 2015 06:29 AM
Ben26
Aug 27, 2015 08:56 PM
Ben26
Aug 11, 2015 04:19 PM
Aug 10, 2015 12:08 PM
