02 mondeo tdci fuel pump fault
Old 29-04-2010, 06:37 PM
  #41
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
Def blank it off rather than replace it. You don't need an EGR valve and it causes loads of issues. Blanking plates are about 4 quid on eBay.
Old 29-04-2010, 07:23 PM
  #42
as355f1
as355f1's Avatar
First thing i would be doing is pulling the fuel filter out, use a torch and inspect it very carefully, almost every time we have had a tdci fuel pump failure there has been metal filings in the filter, we normally change the pump and injectors you need to clean all the fuel lines out to.
its a mega common problem on the mondeos, jags and transits all with the ford tdci engine, done loads.
if your sure its not the pump usually the only other thing that stops them starting is a major duel mass flywheel failure as the crank senor picks up from it,
Old 30-04-2010, 08:41 AM
  #43
sdk72
sdk72's Avatar
whats the agr valve do and where is the bugger? cheers
Old 30-04-2010, 08:43 AM
  #44
sdk72
sdk72's Avatar
did the fuel filter at weekend when i changed the cam sensor. only because i could see it and get to it. fuel was clean coming out no swarf or filings or anything nasty looking.
Old 30-04-2010, 08:44 AM
  #45
sdk72
sdk72's Avatar
would a crank sensor need replacing for this or is it a big job n all?
cheers
Old 30-04-2010, 08:46 AM
  #46
DanW@FastFord
Spelling Club King!
It's an EGR (Exhaust gas recirculation) valve and the silver thing in the middle of the picture...
It basically recycles some of the exhaust gases to reduce NOX emissions but in doing do it collects thick oily sludge, which gums up the valve, and the inlet manifold, to the detriment of performance and fuel economy. Blanking it off (fit the blanking plate where the green mark on the EGR on the picture is) can actually improve performance and economy, and it will still pass an MoT just fine.
Old 30-04-2010, 08:47 AM
  #47
DanW@FastFord
Spelling Club King!
Make sure you fill the filter housing with fuel before trying to start it, otherwise it will be a bitch to start.
Old 30-04-2010, 08:48 AM
  #48
sdk72
sdk72's Avatar
hmmmm; couldn't see that on my 2002 2.0 tdci. would they be anywhere else?
Old 30-04-2010, 08:49 AM
  #49
DanW@FastFord
Spelling Club King!
Is it definitely a TDCi, not a TDDI? It may have an early engine in, and the EGR is at the back right and is a bitch to get to!
Old 30-04-2010, 08:53 AM
  #50
sdk72
sdk72's Avatar
emptied prob half of the fuel and I know I didn't put any back in
Old 30-04-2010, 08:55 AM
  #51
sdk72
sdk72's Avatar
tdci sticker on back of car, so unless the bugger who sold it me swapped the engine????
how can the egr valve stop the car starting?
Old 30-04-2010, 08:59 AM
  #52
DanW@FastFord
Spelling Club King!
Oops!
tdci sticker on back of car, so unless the bugger who sold it me swapped the engine???? how can the egr valve stop the car starting?
I wouldn't have thought it could, but a previous poster said that it cured his?
Old 30-04-2010, 09:01 AM
  #53
sdk72
sdk72's Avatar
cheers. what role does the crank sensor play in the engine turning over?
Old 30-04-2010, 09:05 AM
  #54
DanW@FastFord
Spelling Club King!
"Cam Position Sensor
The CMP scans a reference cam on the camshaft. The CMP sends an alternating voltage signal to the PCM. This indicates the firing position of No1 cylinder. This is only used when starting starting. after that the (PIP) signal takes over to control the injectors.
Crankshaft Position Sensor
The CKP sensor is also an inductive pulse generator, like the CMP which scans 36 minus 1 cast protrusions on the flywheel. Minus one means that one of the protrusions is missing. This missing protrusion is located at 90º before top dead center and is used by the powertrain control module as a reference mark for the crankshaft position. The crankshaft position sensor sends an alternating voltage signal to the powertrain control module, which is used to determine engine speed and ignition timing."
Old 30-04-2010, 09:08 AM
  #55
sdk72
sdk72's Avatar
ok. ta - shoulkd i check / change the CKP sensor then ?
Old 30-04-2010, 09:18 AM
  #56
DanW@FastFord
Spelling Club King!
Have you tried to start it with the new cam sensor, fuelled up filer, and charged up battery?
The CKP would (probably) have been flagged up by the fault codes, so you're more likely than not wasting money changing random things.
Old 30-04-2010, 09:20 AM
  #57
sdk72
sdk72's Avatar
fair enough, will do that on saturday I guess. still waiting on them codes too, the lad said someone else did them for him and he will get the codes of him today. which would help!
Old 30-04-2010, 09:24 AM
  #58
The DIVA
The DIVA's Avatar
it would try and turn over but never fired up. battery so weak it doesn't do that anymore
Hi mate, i`m fairly local to you and i have proper diagnostics if you want me to take a look for you....
It`s not always the pump, sometimes it`s just one of the injectors pops the valve sandwich block and they wont restart.... shows up as fuel pressure low/high on diagnostics...
Give me a bell mate, will PM you my number now
Old 30-04-2010, 09:27 AM
  #59
R4N SS
R4N SS's Avatar
Diva
Old 30-04-2010, 09:44 AM
  #60
sdk72
sdk72's Avatar
appreciate everyones contribution, you do your forum proud !. hopefully I will get this nut cracked now
Old 30-04-2010, 10:40 AM
  #61
wobbles
wobbles's Avatar
Not too sure to be honest....haha. Ran a diag check and checked a few other forums and it seemed to be a fairly common fault so changed it. I wanted to blank it but my mum said "i want it done right, none of you're half arsed efforts!" haha. thats the thanks you get!
Thats been 5 days now and now probs since.
Old 30-04-2010, 10:43 AM
  #62
sdk72
sdk72's Avatar
lol. pretty sure my mums well past caring what i do now. will have a look for it though, apparently mines at the back of engine and a bitch to get to!
Old 30-04-2010, 10:51 AM
  #63
sdk72
sdk72's Avatar
doesn't take much to lose your virginity on ere does it ???
Old 30-04-2010, 11:48 AM
  #64
wobbles
wobbles's Avatar
Haha, na it was her car and i was sorting it as i had nothing better to do.
Old 30-04-2010, 02:33 PM
  #65
sdk72
sdk72's Avatar
I've looked all over tinternet, under the bonnets under the back seat, in the boot & in the glove compartment and still can't find the bloody EGR valve. anybody shed any light or have a pic where the critter lives? cheers
Old 30-04-2010, 02:48 PM
  #66
DanW@FastFord
Spelling Club King!
Back right, under a load of pipes IIRC!
Old 30-04-2010, 02:50 PM
  #67
sdk72
sdk72's Avatar
cheers. will have a look when it stops pissin it down!
Old 01-05-2010, 09:58 AM
  #68
sdk72
sdk72's Avatar
cannae find the EGR valve still. well nothing looking shiney like thing in the pic. However, charged battery, also noticed there was a wire loose on fuel pump. now car tries and turns over but just not firing. there is fuel in filter and coming from filter now. as when it first failed i checked filter and was dry in pipe from filter to engine. now i am covered in it, so that tells me pump is ok after all, right ???? tried turnin it over again and again buty battery is goosed again. is this pointing at injectors as the fault now???? cheers..
Old 01-05-2010, 05:03 PM
  #69
DanW@FastFord
Spelling Club King!
Not necessarily injectors, as a number of things could be at fault. Can you try and bump start it?
Old 02-05-2010, 01:26 PM
  #70
sdk72
sdk72's Avatar
there's now a puddle of diesel around the 2nd injector. plot thickens !
Old 09-06-2013, 04:47 PM
  #71
16vzetec
16vzetec's Avatar
Did you ever get this sorted? Ive got same problem with 03 focus tdci.
Fuel pressure too low.
Wont start without easystart.
When its running its running rough.
How do i test it?
Is it just the solonoid on the pump gone wrong?
Old 21-01-2017, 10:20 AM
  #72
Jason Whittingham
Jason Whittingham's Avatar
Originally Posted by DazC
ran, that is for a tddi engine. a tdci has no electronics on the pump. there is a solenoid valve and a pressure sensor only. need to know more about the fault code and the terminoligy that came out of it to make an informed reply
I have a 05 Mondeo tdci 130 and I had the man read the codes on my car and he said what came up was fuel injection pressure and fuel pump sensor malfunction I'm just wondering if the fuel pump pressure regulator is the problem because them man said that the solenoid brown and blue have gone and I phoned euro parts and they only have the pressure regulator is this the solenoids ?
Rob Wells
18-04-2023 12:19 AM
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
15
07-10-2015 03:43 PM
andrewmctiernan
Wheels and Tyres
03-09-2015 08:22 PM
Quick Reply: 02 mondeo tdci fuel pump fault
