Any Advice welcomes! DMF/Crank Pulley?
Hey guys...
Last week i took my car into the garage to have the Auxhillary belt replaced, as it was making a whining sound. After getting it back, the noise was still there slightly, and the engine made a vibrating type noise. Anyway i ignored it, and the following day the car wouldnt start... *dash LED turned into ---, Red temp warning light was on as well as engine management light*. after 15 mins it started no problem and hasnt happened since. since then the noise in the engine has got much worse.. when i lower the clutch the engine sounds like its going to fall out, very tinny and rattly, any use of the clutch causes the extra noise. I have taken it to 2 garages, one thinks its just the Crank pulley or the tentioner, the other thinks its the DMF... Does anyone have any idea which it could be?
Its a 2002 mondeo, 217k miles.
Thanks!
Thanks!
does the engine rattle badly when youn turn it off ? i had a strange vibration and sound similar to what you are stating, i had the lower pulley replaced and now shes nice and quiet again, well for a diesel anyway!
Before i got the ST I had a ghia x 130 on a 03 plate - DMF cost me £1100 at birchwood ford.
smartst.
smartst.
Umm not really.... the clutch has started to vibrate heavily though.... doesnt help that i do multi drop using the car lol, just hoping it will see me through till Feb when i can replace it! so approx 3000 miles left...
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
