2001 Mondeo mk3 heater problems ?
Old Nov 14, 2011 | 04:40 PM
Garethw1986's Avatar
Garethw1986
Default 2001 Mondeo mk3 heater problems ?
Hi my 2001 tddi Mondeo is only blowing out warm air and the functions that let you change direction of blow ain't working, any ideas? The cars a lx and ain't hot climate control it's just a basic Mondeo thanks
Old Nov 14, 2011 | 08:34 PM
Garethw1986
Anybody? I'm stuck with this!
Old Nov 15, 2011 | 12:59 PM
martysmartie's Avatar
martysmartie
Possibly the cables that connects to the nobs are broken?
Does it feel as if there is any resistance when you turn them?
Martin
Old Nov 15, 2011 | 02:42 PM
dojj's Avatar
dojj
Resident Wrestling Legend
is it knobs or buttons?
www.fordtalk.com will list whats wrong somewhere along the line, but the site became a bit too complicated for me so i couldn't help you with finding out where to start, possibly the wiki link
Old Nov 15, 2011 | 06:06 PM
Garethw1986
It's knobs that you turn, no can't feel any resistance when turning them, thanks
Old Nov 15, 2011 | 08:07 PM
dojj's Avatar
dojj
There are normally issues with the fan motor itself as it sits directly under the pollen filter so it can size up
Old Nov 15, 2011 | 08:11 PM
martysmartie
The Focus suffers from the same issue as well, however the fact the OP says he can feel air shows the motor not to be a problem
I would look at the cables, I should think both of them are broken...
Martin
Old Nov 15, 2011 | 08:16 PM
RS500/364's Avatar
RS500/364
The seal behind this lets water thought silicon grease it and in the motor there a resistor normaly mucks up because of this change it its were the plug connects to the motor job done !
Old Nov 15, 2011 | 08:21 PM
martysmartie
There isn't a problem if you use the seal that Ford provide when you change the filter!
If you don't water gets into the motor and siezes it! The resistor packs are a common failure, again water ingress with the fan can cause this,as you say!
Martin
Rob Wells
Apr 18, 2023 12:19 AM
imnoteasy
Sep 7, 2015 09:26 PM
cossirob
Sep 3, 2015 09:17 PM
Bighandsuk
Sep 2, 2015 05:23 PM
