cooling problem st24
hi guys,need some help......my st24 runs ok but the expansion tank is cold even when the temperture gauge is in the middle,and the heater works fine...i dont understand why the water in the tank is cold when the car is hot?????? can anyone help me please
waterpumps are a common problem on these the blades break up and water stops pumping if left it will do the head gaskets look in the header tank while running and see if water is being returned to the tank
same engine as mine dude check the thermostate next to water pump if this dose not open water will only move between engine and heater its easy to open the stat house just two bolt and an O ring
yep would say stats the problem just take it out and replace it very easy job leave main tank cap on you lose less fluid that way and if your short on cash you can just run without it ps you after any tune up part got a 3l throttle body and a unichip intrested?
chears chaz,i thought it might be the the thermo,im normally good on the cars,not so much ford,vauxhall maybe-used to have a calibra turbo and done an overhaul on that until bottom end went(rings and the rest)....get new thermo in it tomorrow and give it a go.....
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
