Reversing Light
Old Feb 7, 2010 | 09:00 PM
borgie's Avatar
borgie
Default Reversing Light
Mines not working at the moment.
We have checked the bulb. Its OK
We checked the holder which is the same as the fog light holder. Its OK
The holder is getting the voltage so it must be an earth fault.
does anyone know where it will be earthed?
had anyone else had this issue?
Thanks
Old Feb 7, 2010 | 09:23 PM
pending's Avatar
pending
Thanks
Hello,
I worked on a ST-2 recently with the same problem. I changed the bulb holder and it fixed it.. Yours may be the same issue?
Regards
RS-STspares.co.uk
Old Feb 8, 2010 | 03:27 PM
If it's getting no earth, just put in another one(earth wire) is easiest way, could be a bad connection or a break anywhere in the loom, just not worth the hassle imo.
Old Feb 8, 2010 | 08:09 PM
borgie's Avatar
borgie
Unhappy
Originally Posted by www.RS-STspares.co.uk
Hello,
Regards
RS-STspares.co.uk
tried the bulb holder mate from the other side but still did not work.
The fog holder looks, exactly the same.
cheers
Old Feb 8, 2010 | 08:12 PM
borgie's Avatar
borgie
thanks tabetha. I need to do something but would prefer to do it without adding wires and altering.
Old Feb 10, 2010 | 10:04 PM
RichieST's Avatar
RichieST
I'm pretty sure these are switched earth anyway, so you will always have +12v. Check to see if you have continuity between the earth pin and the chassis when reverse is selected.
Old Feb 10, 2010 | 10:18 PM
16imarty's Avatar
16imarty
remove coneter on reveas switch on gear box brige both termials see if it workes if works will need new switch
Old Feb 19, 2010 | 08:13 AM
borgie's Avatar
borgie
thanks Rich170 and 16imarty.
i will check these out.
funny thing is , it worked the other day after i had washed the car. it must be a poor connection.
Old Feb 19, 2010 | 12:18 PM
RichieST's Avatar
RichieST
Do you have parking sensors? If so, do they work? That would rule out switch failiure.....
Old Feb 19, 2010 | 07:41 PM
borgie's Avatar
borgie
No Rich170 , I dont have parking sensors. Annoying little problems.
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
The Enigma
Sep 12, 2015 10:12 PM
