dash and seats form rst into mk2 xr2?
does anyone know if the dash and recaros from a mk3 fiesta rs turbo will fit into a fiesta mk2 xr2??
and if so are thay a straight fir or how much hassle is needed?
there are a few ways you can fit the seats. you can either modify your xr2 runners to make them wider to suit the recaro seats or you can leave the fiesta turbo runners on but cut down the sides of the bolt hole fins which bolt the seat to the car. these wont fit ouright they need cutting down. also cos the fornt of the seat is wider you need to make some brackets up which will accomodate the seats.
this is the way i done it. i suppose the better way is to use the xr2 runners and get a bracket/plate made up to allow for the wider seat.
also the door card will touch the seat and this can be quiet hard to shut the door.
rob.
rob.
07-10-2015 12:56 PM
