Help with wiring a st170 clocks and gauges
I'm wondering if anyone has fitted a st170 clocks and gauge pod into a non st car I'm trying to fit it into my 1.4. Also if anyone has a wiring diagram for the clocks and gauges. Any help is appreciated
can anyone tell me how the oil pressure and temperature gauges read on a st170 I have the panel lights working and now to wire the gauges but I'm not too sure on the sensor or sender unit for the gauge. Any help is useful.
There is no sensor / sender.
The ecu makes up a figure bassed on things like water temp, rpm and so on and sends it to the dash.
No st engine ecu, no pod workie. End off.
