ST170 - which flywheel?
Old Apr 12, 2014 | 11:43 AM
Taz1's Avatar
Taz1
Default ST170 - which flywheel?
Will be ditching the DMF in the next couple of months for a solid flywheel from either TTV or from Clutchmasters. For the sake of simplicity I was going to get the clutch and fly from TTV but have come across a couple of negative comments in various threads. Would I be better ordering one from Clutch masters.
Old Apr 15, 2014 | 08:50 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
Pretty sure Will Pedley Racing still does Fidanza flywheel and clutches for the ST170. By all acounts it's an extremely good conversion and cheaper than buying the standard bits from Ford.
Old Apr 17, 2014 | 06:49 PM
Taz1's Avatar
Taz1
Will def look into that! Favouring importing the Clutchmasters kit with the aluminium flywheel at the moment though. Just waiting for a reply with their recommendations regarding which clutch option to go for.
Old Jun 1, 2014 | 07:50 PM
James1290's Avatar
James1290
My clutch has just gone on my st170. I have just gone for the same dmf to be replaced. I toyed with the idea of putting in a solid flywheel but wondered whether it may reduce the longevity of the engine as there must be a reason ford put it in? I understand it's to take the load as it engages but even if you put in a sprung friction plate with a solid flywheel wouldn't it still be snappy on engagement?
Just after other peoples opinions
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
