Noisy turbo
Old Jul 31, 2013 | 12:18 PM
cartsjohn's Avatar
cartsjohn
Default Noisy turbo
I've got a 2008 focus st 225, it might just be my ears playing tricks but when I boot it the turbo seems to make more noise.
I had it serviced about 4000 miles and 0/30 oil was used. When I had a chat with tim (that sorts out the cracked lines) he said to use 10/40 so I didn't know if that could be part of it?
Cheers for the help in advance
Old Jul 31, 2013 | 12:30 PM
martysmartie's Avatar
martysmartie
No, that is the same viscosity as the correct oil which I imagine is 5W/30.
It will be thinner when cold, however.
What do you mean by more noise, as in a bad noise?
Martin
Old Jul 31, 2013 | 01:20 PM
cartsjohn's Avatar
cartsjohn
When it spins up it's louder, or seems that way
Old Aug 1, 2013 | 11:14 AM
cartsjohn's Avatar
cartsjohn
Come on someone must have an idea, please!!!!
Old Aug 1, 2013 | 11:17 AM
RichieST's Avatar
RichieST
Does it still boost like it used to or does it feel sluggish? Could be a boost leak.
Old Aug 1, 2013 | 11:19 AM
cartsjohn's Avatar
cartsjohn
Still seems to boost the same? It's just louder or seems that way
Old Aug 1, 2013 | 11:23 AM
RichieST's Avatar
RichieST
I would have a check over of the boost hoses etc, it's not uncommon for the intercooler hoses to blow off so one could be leaking a bit. Mine when it was standard used to make a bit more noise some days than others, unless it is starts getting smokey or whining then I wouldn't worry a huge amount.
Old Aug 1, 2013 | 11:27 AM
cartsjohn's Avatar
cartsjohn
Cheers il have a check, thanks for that! I get paranoid with this car,
Old Aug 2, 2013 | 10:18 AM
martysmartie
As said if you have a boost leak the turbo will be working harder to achieve the same boost, which will shorten the life of it!
Check the hoses etc as said, or get a pressure test done!
Martin
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
