st170 clutch problem - can anyone help?
Old Feb 19, 2013 | 10:24 AM
jimmy109's Avatar
jimmy109
Default st170 clutch problem - can anyone help?
Hi everyone,
I'm new to this forum so be gentle!
I just wondered if anyone has had a similar experience to myself. I've had my st170 for just over a year, and recently the clutch started slipping, so i replaced the clutch, but not the flywheel. It's an 03 plate and has done 74,000 miles. With the recent cold weather (below freezing), upon starting the car, it was nigh on impossible to get the car in gear. You could only do it with the engine off. On more than one occasion I had to reverse the car out of the drive, turn the engine off to put it into 1st and then start the car again! For the first 3 odd miles the gears would be a pig to move between - you really had to force it in with some brute force. The feel of the clutch is absolutely fine though. Once the engine warms up, however, selecting a new gear was fine - exactly what you would expect from a new clutch. When the temperature is above freezing there is no problem whatsoever.
The only thing that I can think that may cause this (and I'm not at all mechanically minded!) is that the new, thicker gearbox oil that was replaced when the clutch was fitted is freezing, and so is proving rather stubborn until it warms up.
If anyone could shed any light on the matter that would be much appreciated.
James
Old Feb 19, 2013 | 10:43 AM
RichieST's Avatar
RichieST
I'd get the gearbox oil level checked, the clutch hydraulic line bled again to make sure there is no air in it, and get the adjustment of the gear selector cables checked.
Old Feb 19, 2013 | 11:27 AM
Cosnada's Avatar
Cosnada
Check to see if the clutch pedal is wet. If it has had a clutch then the seals may have gone in the master cylinder. This is a very comon problem and not a blame thing - not the garages fault.
Old Feb 19, 2013 | 09:15 PM
jimmy109's Avatar
jimmy109
Thanks for the reply guys, I'll look into it and report back.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
yatta
May 21, 2016 10:31 PM
dombanks
Sep 21, 2015 08:38 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Tank Mike
Sep 10, 2015 07:56 AM
