ST170 cambelt change
Old Feb 12, 2012 | 02:25 PM
deano2690's Avatar
deano2690
Default ST170 cambelt change
The cambelt is due on my ST170 but after been quoted around £400 to do it I have decided it may be better to do it ourselves, And have a few questions.
How simple is it to do in regards to the vvc? do you need a special locking tool ect?
Any other tips?
The vvc is really the only thing worrying me so any help is appreciated
Thanks in advance
Regards
Dean
Old Feb 12, 2012 | 05:02 PM
deano2690's Avatar
deano2690
No one?
Old Feb 13, 2012 | 05:58 PM
deano2690's Avatar
deano2690
Is this a stupid question or something..........
Old Feb 13, 2012 | 08:22 PM
danme1987's Avatar
danme1987
As farasim aware its no different than any cambelt, locking tools are recommended but not essential. Do the usual marking the cogs and make sure they are still in line when changed.
Old Feb 13, 2012 | 08:33 PM
deano2690's Avatar
deano2690
cheers for that mate, just heard that its a pain and can throw up the engine management light, fault codes ect.
Cheers again mate.
Old Feb 15, 2012 | 09:20 PM
Greasenuts's Avatar
Greasenuts
Hi mate, im new here but am an experienced tech and coincidently only did my st timing belt kit last saturday.
You'll have no problems regarding the vvt, its a sealed pulley and you shouldnt need to disturb it in any way.
As said in the other post, locking tools are not strictly required, use some tippex or nail varnish(!) to mark the position of each pulley, (both cams and crank) before you take the belt off and ensure that none of them are turned until the new belt is fitted. (the cams may jump slightly, use a spanner on the pulley bolt to turn it back to where you need it.)
Also, just incase your not aware, you should really fit a cambelt kit, this includes the belt, tensioner pulley and guide pulley, these pulleys do not need to be marked with paint and are very simple to replace once the belt is removed.
you will need to support the engine from beneath as the offside engine mount needs to be removed.
the water pump pulley is driven by the alternator belt and obscures part of the timing belt cover, so needs to be removed. 3 bolts hold the pulley to the pump and these need to be undone while the alternator belt is still fitted, otherwise the pulley will just spin freely.
other than that its pretty straight forward
hope that helps chief
Old Feb 22, 2012 | 09:16 PM
ThePoons's Avatar
ThePoons
St170
well explained greasenuts! i done mine myself aswell can i just ask how much your kit cost you? mine was pretty much £150 from fords and that was bloody trade!! wtf;s all that about??
Old Feb 23, 2012 | 12:08 PM
Greasenuts's Avatar
Greasenuts
i got a Dayco belt kit from my local supplier, £50 trade
dayco are original equipment suppliers to many car manufacturers so i'm confident in it!
Old Feb 23, 2012 | 12:12 PM
Greasenuts's Avatar
Greasenuts
turns out they're ford original equipment aswell!! bonus
Old Feb 23, 2012 | 06:01 PM
ThePoons's Avatar
ThePoons
St170
That's just great! Our local supplier apparently don't list a belt kit for the car. And it's ford only. And when I got it from fords i had to buy it in pieces and not as a kit. Otherwise yes I would of put a pattern one on. Oh well all done now
Old Feb 23, 2012 | 09:15 PM
shanel's Avatar
shanel
have you a part number for the dayco kit i need to look about getting a kit for mines
Old Jan 17, 2013 | 07:22 AM
Fraserb's Avatar
Fraserb
Dayco part number is KTB408
Old Jun 27, 2015 | 09:30 AM
Blade-St's Avatar
Blade-St
Question
I may wrong here but isn't that can belt kit - KTB408 a 1800 ford kit? Not an st170 kit ?
Chas
Oct 5, 2015 07:13 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
dombanks
Sep 21, 2015 08:38 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
marky_g
Sep 12, 2015 04:26 PM
