Central locking problem
Old Jun 30, 2011 | 08:45 PM
tyson675's Avatar
tyson675
Default Central locking problem
Has anyone ever had any trouble with the remote not working to lock and unlock the car?
I've already replaced the battery.
Sometimes it'll work every time continuously for ten mins,then other times it won't do a thing(lock,unlock or pop boot) for 20 mins of trying,then just suddenly work?!
Old Jul 3, 2011 | 12:34 PM
tyson675's Avatar
tyson675
Shall i interpret the silence as people saying they've never had this problem?
A bloke in the garage said his sons focus zetez wont lock,the replacement part from frauds is 189+vat,so he just puts a crooklock on!!!
Old Jul 3, 2011 | 01:02 PM
thebigmacmoomin's Avatar
thebigmacmoomin
My old Focus wouldnt lock at random. Think it was down to when I fitted ST170 interior door handles, I must have damaged the wire for the central locking.
Old Jul 4, 2011 | 03:29 PM
Bailes1992's Avatar
Bailes1992
I'm going to assume you have a MK1/Mk1.5?
I made this post on FocusOwners.com a few months ago...
Seems as of late a few of our Focuses have spontaneously developed C/L Problems.
The C/L Module is in the drivers side footwell, it's a black box with yellow plugs.
Due to it's position expecially in the winter it gets damp.
Pull out the plugs one at a time (try not to get them mixed up).
Check the plugs for any corrosion, if there is any then scratch it off.
Regardless if theres any corrosion give each plug a small squirt with WD40 and plug it back in making sure you lock it back inplace.
I found 4 wires that had a white crusty substance on it.
Since going this my central locking has been 100%
If this dosen't work chances are you'll need a new centrack locking module. Ł400+ from ford
Old Jul 4, 2011 | 10:06 PM
tyson675's Avatar
tyson675
Ouch...Does it have to be a brand new one or will a 2nd hand one fit?Either off another ST or a mk1 focus?
Old Jul 5, 2011 | 08:02 AM
Bailes1992's Avatar
Bailes1992
Second hand one will be fine, you can get a non remote one if you wanted to just use your key instead.
Old Jul 5, 2011 | 02:53 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
Have you re-programmed the remote? The instructions are in your owners manual.
If not then I'd be concerned that the transponder in the key is on its way out. If you go down to one working key then you'll need to get the car into Ford to have another key programmed (approx Ł100) - if you've still got the vague use of 2 keys then you can buy any blue-chip remote fob second hand, get a keyblade cut at any key cutter and program the new key yourself - hopefully before this one dies.
Old Jul 5, 2011 | 04:55 PM
Bailes1992's Avatar
Bailes1992
Why would a nackered transponder cause the central locking to fail?
Old Jul 5, 2011 | 06:10 PM
tyson675's Avatar
tyson675
I am down to one key.I do however have another fob for a focus,how do I programme it?
I don't have a manual!
Old Jul 5, 2011 | 07:39 PM
Davemurphy007
What do you think holds the central locking code in the key?
I've come across plenty of knackered keys, plenty of knackered lock solenoids, a handful of blown fuses (which lives on the back of the fusebox) but I've never come across a knackered central locking computer.
If you are only down to 1 key already then you're fucked. You need 2 working keys for the car to program a third to work with the PATS and the central locking.
Old Jul 5, 2011 | 08:05 PM
tyson675's Avatar
tyson675
hi davemurphy...
is fucked the ford technical term???lol lol lol
Right...been reading a ford technical how to over on ffoc...
i have a spare focus 3 button fob(originally for my connect)so,i've managed to programme that to the car.
So i have to unlock with one and start it/drive it with the only original coz as u say the transponders knackered.
You can actually remove the glass transponder carefully but as mines goosed by the looks of it id be gaining nothing.
Unfortunately its a trip to fords tomorrow...
I should've bought another connect coz mines bulletproof and never costs me a penny...!!!ha ha ha
Old Jul 6, 2011 | 07:56 AM
Davemurphy007
Tyson - you do know the Connect is exactly the same as a mk1 Focus underneath the body panels don't you?
Old Jul 6, 2011 | 08:00 AM
simo2k2000's Avatar
simo2k2000
My Mk3 Mondeo's central locking hasn't worked for a year. I just use the key to open the doors. I'm not losing any sleep over it ha
Old Jul 6, 2011 | 08:03 AM
Bailes1992's Avatar
Bailes1992
Erm? Your on about the glass transponder in the key for the imoboliser?
I got a remote key with no transponder in it and it works fine?
Just dosen't start tha car?
Old Jul 6, 2011 | 08:36 AM
tyson675's Avatar
tyson675
Dave-yeah i knew that.My vans a tdci too,brilliant it is,just a bit thirsty but she's bulletproof.
I nearly bought a tdci mk1 too on a 53 plate,but for 500quid more i couldve had my st.
I bought the ST.he he
No regrets at all,i love it,all cars have there problems.
Simo-If i unlock the car with the key it sets the alarm off and wont start,mines an intermittent problem,not permanently broke.
stephenb4506
33
Oct 2, 2015 06:25 PM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
