ST170 questions
Old Aug 6, 2010 | 08:27 PM
hump's Avatar
hump
Default ST170 questions
Hi
I have just bought a focus ST170 2002 with 42k and have a few minor questions to ask.
I pulled up the gear leaver gator and there was a yellow piece of plastic around the gear linkage. It was loose and hinged at one point so you can fold it in half and I cant see any use for it at all. Anyone any ideas what this is.
Also the ESP light is always on and I briefly manged to turn it off after fiddling with the button but has come back on again. Is the button broken, is this a common problem?
Finally the engine management light came on the other day but dont know why. The car still runs fine so not sure if i should take it to a garage for them to look at?
Cheers for any help.
Tom.
Old Aug 7, 2010 | 07:17 AM
Ester170's Avatar
Ester170
Hello Tom,
I fitted a quick shift gear link to mine and seem to remember this plastic yellow thing, I think mine was just about snapped off, the new gear linkage hasn't got it either, I believe it serves no purpose.
If by fiddling with the ESP button you managed to switch it off I would say the switch is the problem, but DO CLEAN the connections under the switch first, they may be dirty.
It probably would be cheaper in the long run to buy a fault code reader and do it yourself. The Management light comes on now and again in my car especially if I stall it So I just reset it with my Bluefin.
It can come on if you get a loose loom plug connection for example and as I said above mine comes on if I stall ahem....
You don't want to be paying a Garage to reset the Light for something that you can do yourself.
Oh yeah, also after the light comes on, in some cases if the fault doesn't happen again for a while, the light goes out anyway, but not all cases.
Hope this helps
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
