ST170 Missfire Problem
Old Aug 2, 2010 | 09:04 PM
englandbrad's Avatar
englandbrad
Default ST170 Missfire Problem
Hi i would appriciate any help as i have a prob with my st170 thats begining to do my nut in.
I bought the car and shortly after discovered a missfire under load ( high revs mainly ). The problem became really bad and on one occasion has cut out when driving.
I have changed the coil, plugs and ht leads (all oe equipment, but all looked new when removed so i think the problem was already there).
This has improved the problem alittle but i still have it. Mainly on a long motorway journey or when holding the revs in 4th or 5th i get it.
Thanks in advance
Old Aug 2, 2010 | 09:14 PM
THOR's Avatar
THOR
is the engine standard?
Old Aug 5, 2010 | 09:34 PM
englandbrad
Yeah standard any ideas?
Old Aug 5, 2010 | 10:01 PM
THOR's Avatar
THOR
try an ecu reset, disconect the batterey for 20 minutes, re connect then drive. If if is still doing it it could be a Lambda sensor, Cat, or perhaps fuel pump.
Old Aug 6, 2010 | 01:38 AM
Ester170's Avatar
Ester170
Hello Mate,
is the MIL on? I suspect not as you would of mentioned it.
Follow what THOR says and if you get no joy then maybe try a new fuel filter, as enough fuel might be getting through at low revs but not at high revs, which could also indicate an injector.
Another thing you could try, you say your've changed the plugs and HT leads with the same result, so now I would re-gap the plugs smaller, and see if it's any better.
If it's improved somewhat, then you have low voltage at the plugs. (possible coil pack).
Try what THOR suggested then maybe my suggestions.
Best of luck
Old Aug 6, 2010 | 09:17 AM
TomStarkey's Avatar
TomStarkey
Dose the Engine feel more like its holding back at rev's or like its lost all power? I've had 2 problems with mine, first was the coil pack (engine holding back over 4-5k) and then 6 months later the fuel pump (engine dieing briefly under hard accel over 3-4k)
Old Aug 8, 2010 | 10:06 PM
englandbrad
hi yeah its more of a loss of power has been quite violent at high revs.
Old Aug 8, 2010 | 10:07 PM
englandbrad
Cheers mate given me something to go on the ecu reset would be a great result if that works. cheers
Old Aug 8, 2010 | 10:09 PM
englandbrad
Originally Posted by Ester170
Hello Mate,
Best of luck
I have change the coil that improved it alot in low rev but now its just top end and when i hold the revs. Will give the above a go.
Old Aug 8, 2010 | 10:10 PM
englandbrad
Cheers for all the info, hope i get to the bottom of it as it's spoiling such a great car to drive.
Will let you know.
Thanks brad
Old Aug 8, 2010 | 11:34 PM
TomStarkey's Avatar
TomStarkey
Sounds like a fuel issue to me, filter and or pump. Happened to me and from what your saying sounds the same. Unfortunately the pumps in the tank and so is a pain to do. Hope it turns out to be something cheaper and easier for you
Old Aug 9, 2010 | 12:02 AM
hillzy2k's Avatar
hillzy2k
if it is the pump its not too said a job to do, but the tank does have to be dropped at least. not always necessary to completely remove it as ive done a few pumps on normal foci, one thing to consider though is im unsure if the pumps in a shopping spec focus are the same as st170. the st uses a different fuel line setup without a return so i dunno if the pressures are different. BRAINWAVE>>>> PRESSURE REGULATOR ANYONE????????
Old Aug 9, 2010 | 12:14 PM
Sp3no's Avatar
Sp3no
A pressure regulator will put additional strain on the pump, as said your Fuel pump is knackered, very common problem, get it chaged and get an uprated in tank Syntec one, they are less than £200
Old Aug 10, 2010 | 10:55 PM
englandbrad
Have driven the car for some distance today and i noticed that the problem incresed as the journey went on it seem ok to start and then gradually got worse and worse until it was almost constantly missing with any amount of pressure on the pedal.
Does this help to diagnose.
cheers
Old Aug 12, 2010 | 06:47 PM
RichieST's Avatar
RichieST
I'd say fuel pump too!
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
Tank Mike
Sep 10, 2015 07:56 AM
