Mk1 focus RS help please
Old Nov 4, 2013 | 08:05 PM
cossieant380's Avatar
cossieant380
Default Mk1 focus RS help please
I can anybody help. Had a new clutch fitted to my mk1 focus rs
And now car will not idle properly and hunts when it idling and when you floor it in 1st it backfires
Car is a phase 2 with uprated actuator and re-circ dump valve and decat mongoose and a bluefin
But never had this problem before went in for clutch
While car was in for clutch we fitted and new atmo dump vale and boost pipes new ford plugs new ford fuel filter
We have now taken off the atmo dump valve boost pipes and put it back to how it was before the clutch job and even put old plugs back in
Can anybody help please
Old Nov 4, 2013 | 08:23 PM
stevos's Avatar
stevos
I would be looking for a vacuum leak mate spray some brake cleaner around the vac pipes and listen for the idle change.
Old Nov 4, 2013 | 08:25 PM
MATT222's Avatar
MATT222
There is a pipe that goes to the carbon canister that can snap, causes an air leak also the vac pipe splits and causes various faults.
Old Nov 4, 2013 | 08:30 PM
cossieant380
Do you mean the breather hose with the white one way valve
Old Nov 4, 2013 | 09:06 PM
MATT222's Avatar
MATT222
That's one of them the other is on the left hand side in the engine bay near the pas bottle
Old Nov 6, 2013 | 09:39 AM
Lami's Avatar
Lami
Looks a bit like this, its on bulkhead on LHS as you look at it
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
massivewangers
30
Oct 1, 2015 07:40 PM
richierich1986
Sep 18, 2015 03:29 PM
JamboRS
28
Sep 14, 2015 09:02 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
