fuel tank removal
fuel tank removal
i have a fuel pump to change on a focus was wondering what is the best procesure to remove the tank because the pump needs to be replaced and if by any chance would any body have the part numbers for the pump
Why wasn't the Focus designed with an access under the rear seat..............
Try to do it when the level is low !
Undo the filler and vent pipe, disconnect and remove charcoal canister at rear. Disconnect filter (good idea to replace it while tank is dropped). Support tank, undo strap bolt. Lower tank, disconnect pipes and wiring. Undo access retainer and remove top cover. Turn fuel module to release from bottom of tank.
Might have changed, but Ford use to only supply a complete 'fuel module' though its easy to dismantle. Good after market suppliers (FSE in UK) can supply a bare replacement pump. Any where else, check against original pump as there are subtle differences, for example, in outlet pipe position.
Martin
Martin
steerfromdarear
28
29-01-2016 06:14 PM
ekjim
17-08-2015 08:57 PM
