clutch
Old Jul 26, 2010 | 03:15 PM
sykes2009's Avatar
sykes2009
Default clutch
hi i have got a mk2 focus 1.6, the clutch seems to bitting high but the fluid is ok
so im thinking it might be on its way out what performance clutch could i replace it with where it would be a straigh swap even if it isnt going i am still thinking of replacing it as its coming upto 50,000 miles now and i want to freshen the car up along with a good service
Old Jul 27, 2010 | 02:06 AM
phil_focus's Avatar
phil_focus
i wouldnt replace a clutch at 50k just for the sake of replacing it. i've known cars with 150k-200k with original clutches still doing well!!
what sort of driving do you do and when you come to a stop at traffic lights and junctions do you hold the clutch at the biting point or put the car in neutral and the hand brake on??
also on a 1.6 i dont see the need in an uprated clutch!
Old Jul 27, 2010 | 05:26 AM
rubinsbin's Avatar
rubinsbin
if its high(pedal)you need or will be needing a new clutch in the not so distant future,
also get the hydrolics also (ie 3 piece clutch) if you dont and its goes faulty its start over again time!!!!!!,
NO NEED TO UPRATE IT ,USE STANDARD ITEM
Old Jul 27, 2010 | 10:28 AM
sykes2009's Avatar
sykes2009
fair enough if i replace it i will use standerd item, at lights i put clutch down leave it in 1st and have my right foot on the break, to be honest i think it is also
my seat position i have long legs i moved the seat back its a lot better but my misses drives it to and she's a short arse so the seat dose not always end up in the same position, but even after all this it still seem's to be bitting a bit high
when it goes in for a services a will see what they say
Old Jul 27, 2010 | 10:32 AM
phil_focus's Avatar
phil_focus
could be the pressure plate has weakened a little due to foot being on the clutch soo much.
Old Jul 27, 2010 | 10:57 AM
m4tt274's Avatar
m4tt274
wouldnt have thought u would need a performance clutch on a 1.6
Old Jul 27, 2010 | 12:01 PM
sykes2009's Avatar
sykes2009
^^^^^ no i proberbly dont i just thought about one if i needed to replace it
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
