question on st170??
Old May 17, 2010 | 05:34 PM
ricky_2006's Avatar
ricky_2006
Default question on st170??
i have a st170 with the extra (added) sub in back from standard and the 5"x7" in back and front.
just wondering wether anyone has upgraded these atall because was thinking of doing it.
and wanted to know which ones you went for
thanks
Old May 26, 2010 | 09:22 PM
ST_BEAN's Avatar
ST_BEAN
thanks
not worth it mate standard speakers are good quality only thing you could look at is bigger sub but that means upgrading the amp and the head unit
Old May 27, 2010 | 09:23 AM
Sp3no's Avatar
Sp3no
I replaced my front 5x7's with JBL's which are a straight swap, they sound allot better than the standard speakers although the standard ones are not bad. If your bothered about bass then ditch the rear speakers all together i disconnected mine. Mid range and Top end sounds need to be directional, ie focused on the listener, bass is not directional you can run a sub anywhere. I had 2 12" 800W Pinoneer subs in the boot with an amp and the sound quality was out of this world but i got tired of the bass so swapped the subs for some vibe square 6x9 hidden under a custom made stealth shelf run by a 540w 4 channel amp which i have bridged. I miss the bass but it still sounds spot on specially when watching a DVD
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
