st170 front brakes help
Old Apr 21, 2010 | 07:17 PM
airzfocus's Avatar
airzfocus
Default st170 front brakes help
planning of fitting hubs and rest of set up this week to my 1.8 focus, will i need to use the shafts of the st170 or will my exsisting driveshafts fit into the splines on the st170 hubs, cheers
also if i do need to use the st shafts will i be able to split them so i just use the outter shaft for the hub and use my normal shaft from the box and join them up?? if ya get what i mean! cheers
Old Apr 21, 2010 | 07:57 PM
MisiekT_PL's Avatar
MisiekT_PL
no reason to change driveshafts
Old Apr 21, 2010 | 08:48 PM
airzfocus's Avatar
airzfocus
so my zetec shafts will fit fine into st hubs? cheers
Old Apr 21, 2010 | 08:56 PM
phil_focus's Avatar
phil_focus
no need to change shafts, they fit perfect.
done it on my 2l which has the mtx75 box and loads have done it on 1.8s and 1.6s.
i warn you now though the hub nuts need torqueing to 316 NM!!!!! i had to buy a new torque wrench to do this job and that still only went upto 300NM so just tweeked it a bit more
Old Apr 21, 2010 | 09:08 PM
airzfocus's Avatar
airzfocus
sorted, means i can prob rack some money back off the st shafts!
original
Apr 28, 2026 05:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
C2 MAK
Aug 20, 2015 09:46 PM
Aug 10, 2015 12:08 PM
