st 170 juddering when driving
Old May 6, 2009 | 04:51 PM
g350 aar's Avatar
g350 aar
Default st 170 juddering when driving
my sisters st 170 judders when driven wether its crusing at normal speeds or pulling off any ideas???
Old May 6, 2009 | 06:22 PM
wide ka's Avatar
wide ka
flywheel? there a dual mass
Old May 6, 2009 | 09:54 PM
RichieST's Avatar
RichieST
Does it make any unusual noises?
If it feels like its surging then it could be lambda sensor, mine used to do it til i changed the lambda!
Old May 7, 2009 | 04:03 PM
g350 aar's Avatar
g350 aar
it sounds like a diesel on tick over, has had the oxygen sensor replaced as the ecu showed it was at fault, also its very flat throughout the rev range
Old May 7, 2009 | 04:04 PM
g350 aar's Avatar
g350 aar
is this a common problem??
Old May 17, 2009 | 05:47 PM
LewisST170's Avatar
LewisST170
would appreciate replies on this also, my 170 has the same symptoms.
Old May 17, 2009 | 06:14 PM
RS Juto's Avatar
RS Juto
Flywheel....... and they are Ł300
Old May 22, 2009 | 11:35 AM
noonan3000's Avatar
noonan3000
Mine has the exact same fault, no warning light and a judder when above 3k revs.
Replaced lambda,crankshaft sensor,plugs,leads & coil pack to no avail.
Last night i changed the fuel filter and it is much better but not quite right stil. Spoke with a number of Ford specialists and they have all said the fuel pump is what needs changing.
Looking into this so will update when fitted....
Old May 22, 2009 | 12:41 PM
RichieST's Avatar
RichieST
That'll be the dual mass flywheel then!
Old May 22, 2009 | 01:17 PM
noonan3000's Avatar
noonan3000
Mate you need to be employed by every ford tuning specialist in the country becasue non of them suggested that!!
Old May 28, 2009 | 05:44 AM
noonan3000's Avatar
noonan3000
Fuel filter fitted and guess what......problem fixed!!!
Old Aug 25, 2009 | 08:53 AM
brebspc's Avatar
brebspc
My st170 also sounds like a diesel on tick over, did you ever figure out what it was??
Old Aug 25, 2009 | 08:55 AM
brebspc's Avatar
brebspc
Old Aug 25, 2009 | 11:32 AM
Sp3no's Avatar
Sp3no
The ST170 does have noisey top end due to the solid lifters and uprated cams. It does not sound anywhere near that of a diesel though
Old Aug 25, 2009 | 05:21 PM
RS Juto's Avatar
RS Juto
Does the noise go when you depress the clutch
Old Aug 26, 2009 | 01:37 PM
brebspc's Avatar
brebspc
No, but probably just getting used to the noises the car makes as standard. Thought it would sound smoother, thats all. Thanks.
Old Aug 27, 2009 | 01:37 PM
seve170's Avatar
seve170
Default 170
hi my st170 judders in between 1000rpm to 2000rpm and when over 4000rpm it seems to lose power and won't rev rite up have already changed the fuel rail,fuel filter.crank sensor,air flow mass metre,plugs and yesterday the coil pack but still the same so i,m ready to crack up! anybody with any ideas would be much appreciated
Old Sep 2, 2009 | 11:01 AM
mozzy's Avatar
mozzy
Ford for life
that sounds like the imrc, look on the end of the inlet manifold and you will see a cable , there is a black plastic thing there, they are prone to wear and breaking etc,
the imrc is the inlet manifold runner controller, the is a solenoid on the bulk head which controls it all. its what gives the nice surge of power at 4000 rpm
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
martynhomer01
14
Sep 23, 2015 12:23 AM
